ProXellent keyboard only working in BIOS
EnthusiastDude
11 May 2020, 14:58
Update: Solved it by using a different converter
So I bought this awesome NIB "ProXellent Transkey" keyboard recently, because it has a great layout and it supports no software macro keys, which is a neat feature that I always wanted to try.
I plugged it into my small AT to PS/2 and PS/2 to USB converters, expecting it to work like every other AT keyboard in my collection. And then absolutely nothing happened. I tried to get it working myself and long story short it works in my BIOS, but doesn't as soon as I boot into Windows (or mac OS, it's a hackintosh).
I've never experienced this behaviour and I have no clue what could cause this. I really like this keyboard so far and I'd really appreciate any help that I can get.
Here's a picture of it, for the curious among you:
11 May 2020, 16:25
That's a weird issue, but I suspect the PS/2 to USB converter. So the same converter works with other PS/2 keyboards, huh? Have you tried it on another computer?
One hypothesis, albeit far-fetched, is that the keyboard and converter draw too much power on the port, and so the Windows and Mac USB drivers (because they are more sophisiticated than BIOS) decide to turn it off. I dunno.
EnthusiastDude
11 May 2020, 16:57
Findecanor wrote: 11 May 2020, 16:25 That's a weird issue, but I suspect the PS/2 to USB converter. So the same converter works with other PS/2 keyboards, huh? Have you tried it on another computer?
The same converter works for other keyboards, but I'll try a different one later to see if that changes anything. I haven't yet thought about power, thanks for that hint. I'm unsure how I can find out if that's really the issue, would you have any idea how I could go about that?
Polecat
11 May 2020, 17:46
Does the keyboard have an XT/AT switch or is it autodetect? If it has a switch try the other mode. If it's autodetect try another converter. May be a conflict if both the keyboard and converter (and OS) are trying to set the mode.
EnthusiastDude
11 May 2020, 18:11
I tried the other converter and it worked! The funny thing is that the converter still works for other keyboards, but somehow doesn't like the ProXellent. Thanks everyone for helping me solve this!
Polecat
12 May 2020, 04:03
EnthusiastDude wrote: 11 May 2020, 18:11 I tried the other converter and it worked! The funny thing is that the converter still works for other keyboards, but somehow doesn't like the ProXellent. Thanks everyone for helping me solve this!
Nice! I'd like to know more about this keyboard. Switch type? Is it related to Focus/Northgate? I've seen a couple of these for sale, but passed because I didn't know anything about them. At your convenience, of course, glad you got it working.
EnthusiastDude
12 May 2020, 12:18
Sure, it comes with linear alps clones with a green slider and I am pretty sure that it was manufactured by Focus, because the keycaps look like they are the same as on my fk-3002.
Pretty sturdy construction too, I really like it.
It came with a lot of features including the before mentioned macro programmability and the manual states that "it is the most powerful hardware and software" :)
Polecat
13 May 2020, 02:59
EnthusiastDude wrote: 12 May 2020, 12:18 Sure, it comes with linear alps clones with a green slider and I am pretty sure that it was manufactured by Focus, because the keycaps look like they are the same as on my fk-3002.
Thank you, much appreciated! The linear switches are a surprise. The other ProXellent posted here had white (clicky) Alps. How does the macro thing work? I have an FK-2002 with a macro key, but all it does as far as I can tell is generate a backslash with a different scan code than the one in the alpha area. Not enough electronics inside to be programmable, so it must have triggered a TSR program or something. I bought it new, but it didn't come with any software or instructions on how to use the Macro function.
EnthusiastDude
13 May 2020, 09:07
Yeah it was a bit surprising to me too, but I like it. I think linear clones are closer to the originals than clicky clones.
The Macros work the following way: First you press the right alt + ctrl + macro key to get into macro mode. This is signaled by the macro lock light. Only in macro mode macros work, otherwise all the keys have the normal functionality (for example F1-F12). To program a key, you press scroll lock, then the key that you want to program (all F-keys and the diagonal arrow keys are programmable). Then you enter up to 32 keystrokes and then you press the key that you want to program again. This makes the keyboard leave macro mode to show that it worked. And that's it, sounds complicated but once you've done it one time it is really easy to remember.
But if I haven't had the instructions I would never have figured that out.
Polecat
14 May 2020, 04:07
EnthusiastDude wrote: 13 May 2020, 09:07 Yeah it was a bit surprising to me too, but I like it. I think linear clones are closer to the originals than clicky clones.
Priceless info. A year or five from now someone will be profusely thanking you for sharing it. I'll try that procedure on my Focus, but it doesn't have a Macro Lock LED, nor electronics inside for anything to be stored by the user. Just the usual 8xxx controller chip. Does the ProXellent save the macros when powered down or when the computer is rebooted? The last generation of Northgates had a (notoriously flaky) EEPROM, but prior to that storing small chunks of data on the fly was a lot more difficult. Thanks again!
EnthusiastDude
14 May 2020, 08:38
Yeah, I guess it's not that intuitive. I haven't opened it up yet, so I can't say which chips it has, but it does save the macros even without power so I guess it has to have an EEPROM or something alike. Pretty neat in my opinion, I prefer it to macros that have to be configured with software.
Bjerrk
11 Jun 2021, 12:21
EnthusiastDude wrote: 14 May 2020, 08:38 Yeah, I guess it's not that intuitive. I haven't opened it up yet, so I can't say which chips it has, but it does save the macros even without power so I guess it has to have an EEPROM or something alike. Pretty neat in my opinion, I prefer it to macros that have to be configured with software.
Hey EnthusiastDude, how do you like the keyboard? I'm assuming this is the exact same specimen?
EnthusiastDude
15 Jun 2021, 00:52
Hey!
Yeah, it's the same board. I like it, but the BAE layout is a deal breaker for me. The no-software, on the fly programmable function keys should be on every keyboard, best feature ever. The switches feel and sound very similar to yellow alps. Build quality is pretty good, not model M but way better than g80-3000s. And the condition is like brand new.
Polecat
20 Nov 2022, 05:38
I just tried both ProXellent (Alps and rubber dome versions) Macro routines on the Focus FK-2002, and as expected they do not work. Oh well, nothing ventured, nothing lost.
