Flashing TMK to Pro Micro for ADB converter
- Main mouse: MX Master 3
Hi guys, I am building a converter for an M0116 and it seems I will have to use TMK. Physically building the converter is super easy (for me, anyway) but I am not quite sure how I should flash it. Is it as simple as with Soarer's firmware where I just download one .hex file and flash it with avrdude (I am running Manjaro Linux)? Or is there more to it? Thanks!
- abrahamstechnology
- DT Pro Member: 0212
I think you just download the hex file and flash it after shorting the pads to change the mode, (personally i've used Atmel FLIP)
Where do I download the hex file? I skimmed the Github page (for the ADB converter) and it was talking about building one from scratch.abrahamstechnology wrote: 18 May 2020, 17:58 I think you just download the hex file and flash it after shorting the pads to change the mode, (personally i've used Atmel FLIP)
- Main keyboard: Model F77
- Favorite switch: Alpaca V2
You set your layout, generate the hex here and download and flash with AVRdude
http://www.tmk-kbd.com/tmk_keyboard/editor/
Awesome, will give it a shot, thankskmnov2017 wrote: 18 May 2020, 18:38 You set your layout, generate the hex here and download and flash with AVRdude
One question though, which pin on the Pro Micro is PD0? I think the Github guide is for a Teensy but I am not certain.
- swampangel
Pin 2 on the pro micro is PD1, and pin 3 is PD0kelvinhall05 wrote: 18 May 2020, 18:40 One question though, which pin on the Pro Micro is PD0? I think the Github guide is for a Teensy but I am not certain.
