Hi guys!
I'm tempted to build a TKL-board with SKCM Brown but I don't have a matching keyset.
I've been reading and googling a lot and I was under the impression that my two best options were either a SGI- or a Dell AT101 keyset, but maybe there are other, nice and thick Alps keyset out there that would work?
(no aek2, I already have a Lunar built with those)
Great TKL Alps keysets?
- Main keyboard: Zenithi ZKB-2
- Favorite switch: Micro Switch SW-Series
Northgate Omnikeys have Ansi layouts: https://www.ebay.com/itm/274379109319
But a Dell AT101 is probably your best bet since you can typically find them somewhat cheap (relatively)
- fohat
- Elder Messenger
- DT Pro Member: 0158
I would look at Tai Hao's offerings:
https://www.tai-hao.com/catalog/ins.php?index_id=83
https://mechanicalkeyboards.com/shop/in ... list&c=430
If you want vintage and are looking for doubleshot ABS there are numerous options, if you want dye-sub PBT you are more limited.
*Some* very early Dell AT101s (not AT101Ws) and SGIs have them, and some Wang 724/725s.
- Chyros
I'd just buy a new Tai-Hao set tbh. Uses modern, standard key sizes, which most Alps keyboards don't. The only other one is basically the AT101W which has pretty crap caps.
- Main keyboard: AEK
- Main mouse: Logitec MX
- Favorite switch: ALPS Salmon
They're not much thicker, but they are much nicer than silitek manufactured AT101/102 caps.ZyBeR wrote: 02 Jun 2020, 15:54 I have no experience with Tai-Hao but from the looks of it they are very thin, similar to the ps2 model at101?
If I wasn't a die hard ISO user I'd be all over Tai-Hao caps. I wish they'd do a standard ISO set.
I sent an enquiry what the cost and minimum order would be to run https://shop.tai-hao.com/products/abs-104-c01bu201 in alps mount. With ISO & 7u bottom row kits too.
Would this not be an ideal set? it's my fav taihao colour way.
