Ready to use Keyboard controller for up to 8 x 8 keys
TheBug
08 Jul 2020, 16:39
If you want to skip the step of programming the firmware for your keyboard, here is the right solution for keyboards with up to 64 keys in a 8 x 8 matrix.
KeyWarrior28 is an industry grade keyboard controller made by Code Mercenaries, it is based on 22+ years experience in the keyboard business. The KeyWarrior28-MOD is a PCB module with a ready to run configuration, you only need to add keys and a USB cable.
Each of the 64 keys can generate a single key stroke, a key plus a modifier, one of 19 programmable macros, or a mouse move or button. Right, it also works as a mouse. There are two FN keys available for a total of three keyboard layouts. FN keys and modifiers can be programmed to be locking or sticky, allowing mode switching or single handed operation.
Macros can have up to 31 key codes and generate them statically, like typing, or step through several codes like a cell phone numeric keypad when texting.
All functions can be programmed via USB with an easy to use editor.
https://shop.codemercs.com/en/keywarrior28-module.html
Return to “Vendors”
