NMB Hi-Tek PC122 with somewhat scratchy tactile grey space invaders, pretty obscure board. cant figure out the right protocol, seems to output weird stuff and i sadly dont have a mini din soarer to test it really (i was informed it should work with a soarer though). cosmetically in good shape, pbt dye-sub caps, "2" key-cap has a black scratch on it, case is slightly but evenly yellowed. some caps are slightly shined, plate has some oxidation on it. compartment on the back is empty. - 90€
Se Jin SKM-1040 mirrored "ergo" board, inv. cross-mount futaba ma switches, pbt dyesub caps. very smooth and a real delight to type on. slight yellowing on the case, switch on key "u" sometimes only registers when bottoming out. beside that condition is very good, almost unused. - 70€
OKI HMB-35957U-15 oki gourde spring, linear(?) version. does NOT click. melissa is very clean, misses one spring (moved to "pause" key) and some keys feel bindy - 50€
Datacomp DFK191/121, only slightly but evenly yellowed. skcm pine white switches, bindy and scratchy. otherwise very clean board, thin doubleshot abs caps. cable is stretched out. - 50€ SOLD
IBM M122 from 1987, needs boltmod, misses one case screw - 90€ SOLD
IBM F XT with floss mod, new felt feet, mint condition beside the cable - 180€ SOLD
NIB Chicony 5162 with blue alps, only opened it to confirm its blue alps - 550€ SOLD
IBM M122 from 1997, native PS2 w Locklights. needs boltmod, missing 3 caps - 90€ SOLD
Tandon Hitek 725, lubed with krytox, white linear space invaders - has a small scratch on spacebar - 90€ SOLD
NTC 6163 with amber omrons, case is basically curry, very nice build quality. keys on alpha block all work, numpad is mostly dead, navcluster is mostly dead. - 20€ SOLD
Highscreen G80 case, Focus FK2000plus Case and a m0118/m0116 case - for shipping costs.
timestamp:
NOTE: prices arent final, you can always make reasonable offers.
sold:
cherry og iso-de dyesubs. from highscreen board, mint condition. 60€ SOLD lauer and fischer G80-1800, nothing special but has decent smooth blacks. 20€ SOLD OG G80-1800 WKL pcb, has scratchy blacks. M date code. 15€ SOLD G80 DIN cable, new condition. 10€SOLD G80-3000 case, good condition, no yellowing. 15€SOLD Bag of thin lasered caps, full wkl layout. you can have them for free if you want to lol.- chicony 5162 with blue alps 200€SOLD -focus (escom branded) fk2000plus complete with dustcover and all feets. skcm white alps (7/10) 100€ 85€ -broken apple m0110a with mitsumi standard, very good condition optically and the switches feel very good. sadly doesnt work, i think chip was fried. good for parts or custom pcb. original cable included 80€ oboSOLD -apple m0118 with skcm salmon, good optical condition, switches arent that good. 50€ obo SOLD -tinkerboy adb converter 40€SOLD -G80-1501 M date code, pretty smooth blacks, saw heavy use in doctors office. full nkro, sits in G80-1000 case, reader is missing. doubleshots are shined. switchfilmed and case stuffed with foam (fully reversible). 80€ oboSOLD
ask me for more pictures or infos via PM.
im located in germany and prefer to only ship within europe. if you are desperate we can work something out though
cheers!
I love that G80-1000 case. Is there an aftermarket programmable pcb made for that ? I'd love a board that looks like that and has my desired switches+programmable + detachable cable
you can stick the gh80-3000 pcb from maarten in it, afaik its open source by now. has all the desired features and supports both locklights in the panel and in the windowed caps. cheers
Thanks for the great info ! Would you consider letting go only of the g80-1000 case ? Looks pretty good in the pictures, no marks ...
It's worth noting that some PC122s do not use a standard protocol and don't send release codes for non-modifier keys. A USB controller replacement is pretty quick since the matrix is full diode (at least mine was).
