Hi all,
Looking to trade this ANSI modded and completely restored IBM Model F AT for an unrestored / broken IBM model F 122. This F AT was thoroughly cleaned, and has had the degraded foam replaced with new foam. It has also been converted into a US ANSI layout. While not pictured here, I have a NOS black DIN cable on the way. The space bar has not been shortened, and no extra Alt keys have been added. I would like to trade for an F122 in semi decent condition. It does not need to have all the keycaps, nor does it need to work. It would be preferable if the case was in good condition and relatively undamaged, and it had all the flippers intact.
[US-PA] [H] ANSI modded Model F AT [W] Model F 122
- Main keyboard: IBM MOPAR FSSK
- Main mouse: Logitech G502 Lightspeed
- Favorite switch: Brown Alps
- IMG_20200829_152138.jpg (93.6 KiB) Viewed 3715 times
- fohat
- Elder Messenger
- DT Pro Member: 0158
I am not interested in your deal, but I recommend that you include a few photos.
Also, you should say whether your "ANSI mod" includes shortening the space bar and adding Alt keys, that might make it quite a bit more enticing.
