Hey everyone,
Just got a new Model M terminal keyboard and the soarer converter as well. Unfortunately, none of the keys A to ' are registering, along with four function, a few num pad, and the alt/space keys. It works with the original IBM terminal 100%, but I have a feeling I have to remap and have no clue how to do so.
I've got hid listen and they do not appear when I press them, and I've downloaded Soarer's sctools v.1.10. Any tips?
IBM Model M 1395162 Soarer Config
- Redmaus
- Gotta start somewhere
Are you using the latest soarer config? Also before messing with soarer's too much I would try TMK. The terminal_usb or xt_usb should work.
https://github.com/tmk/tmk_keyboard/tree/master
I would say its a membrane issue but since it works fine on your terminal that is doubtful.
- Main keyboard: IBM Model M
- Main mouse: Logitech
Not sure which board you’re working with. At the risk of offending you have you flashed the converter with the Soarer’s firmware? I ask because you have to do that first. When you use HID listen does it just say ‘Listening............’?
- Redmaus
What soarer converter do you have? Is it one of the adapter ones from Orihalcon or are you using a pro micro/Teensy?destuba wrote: 14 Sep 2020, 19:10 Not sure how to update it. I downloaded tmk, but I don't know how to use that either. Does that work with my converter? It's from tinkerboy.
Like mentioned, I am clueless right now.
- Main keyboard: KBParadise V80
- Main mouse: Razer/Omen
- Favorite switch: Buckling/Kalih Light Blue
I have not-- how do you flash it? I know hid listen recognizes when I press any other key. Do you have to run one of the exes in the soarer download? This is a '93 terminal model m.Tbernstein2368 wrote: 15 Sep 2020, 03:44 Not sure which board you’re working with. At the risk of offending you have you flashed the converter with the Soarer’s firmware? I ask because you have to do that first. When you use HID listen does it just say ‘Listening............’?
This is the converter I have.Redmaus wrote: 15 Sep 2020, 04:04What soarer converter do you have? Is it one of the adapter ones from Orihalcon or are you using a pro micro/Teensy?destuba wrote: 14 Sep 2020, 19:10 Not sure how to update it. I downloaded tmk, but I don't know how to use that either. Does that work with my converter? It's from tinkerboy.
- Redmaus
I'm actually not sure how to troubleshoot this then as there is no nondestructive way to access to reset pin.
I would contact who you bought it from and explain the issue to him.
