i was trying to install drivers in iCUE for my K55 keyboard but iCUE did not detect it so i googled it and found someone saying that holding PAGE UP and PAGE DOWN should make iCUE detect it and it did but the download got stuck at 100% for 2-3 hours or so while i was away so i aborted the update when i got home thinking i was just gonna have to live without the drivers since it worked without them. restarted my PC and it seems fine untill i press any button on it, the RGB gimp rainbow effect stops and the buttons wont do anything when i press them. only way i can use it now is by holding Page up and Page down while pluging it out and back in again.
Anyone know how i can fix this.
K55 RGB issue
- Main keyboard: Kinesis Model 130
- Main mouse: Logitech M-S48, Razer Viper
- Favorite switch: MX Browns
If you can find a user or service manual you might be able to find out how to do a factory reset of some sort. Is there any way you could contact Corsair customer support?
