[GB]YMD75% Aluminum + Acrylic Light Support End In Dec 26
David Chen
05 Dec 2020, 10:43
Group buy A: Kit 1 or only case
Group buying start time: UTC+8 2020/12/12
End time:UTC+8 2020/12/26
Production time: About 2 months
Shipping way: FedEx
Ymdkey will use shopify to launch group buy for the new diy kit,this case is made by CNC anodized,design in professional team.
Order links and detail: https://ymdkey.com/products/coming-soon ... 4e79&_ss=r
Contactable Email:[email protected]
Service
Assembly Service(need to be added)
FAQ and after-sales Service
Kit 1($145)
Case (plate embedded-in): CNC Anodized Alu top+Acrylic Base+Plate(color is same with case)
PCB: YMD75v3 QMK Hotswap PCB with RGB underglow
Stabilizers: Gold-plated clear screw-in stabilizers or OEM Clip pcb stabilizers for options
Screws: M2*6 flat
Rubber feet
Only Case($95)
Case (plate embedded-in)+screws+rubber feet (Compatible with Type C YMD75 V2 V3 PCB,KBD75 Type C PCB)
MrSqoon
06 Dec 2020, 11:50
Link does not work?
David Chen
07 Dec 2020, 10:23
Have changed the start time to 20/12/12 UTC+8.
