Are those anything good?
Lalaland124
02 Feb 2021, 19:58
Ejo, I just found this online. Wanted to know if it's anything I should buy :)
It's a privileg NB laptop, a Highscreen Laptop 8100, A Toshiba tecra 730, and a Zenith supersPort 286, IBM N33 SX and a Sumitronics Tw 302 Typewriter.
Thx in advance :))
02 Feb 2021, 21:19
I think the top is a light linear that you'd often find in typewriters but pretty much nowhere else. I'm not a fan myself.
The bottom is Low-profile Alps. They have a reputation of being fragile.
zrrion
02 Feb 2021, 22:34
Findecanor wrote: 02 Feb 2021, 21:19 I think the top is a light linear that you'd often find in typewriters but pretty much nowhere else. I'm not a fan myself.
The first one is actually this: viewtopic.php?f=62&t=24608
There are actually 2 versions of this switch, one with a complicated slider that is like a short version of this and the other is just dome over slider. No way to differentiate them from pictures from what I can tell. Never mind, the slider is different between them. It should have triple shot caps though.
2nd switch is ALPS, but it isn't good. Its a slider and buckling rubber sleeve over membrane.
3rd and 4th are likely some sort of alps common mount.
Lalaland124
03 Feb 2021, 00:00
Thx a lot!!!!
Scarpia
03 Feb 2021, 22:19
The Zenith is probably Alps integrated domes:
wiki/Zenith_Supersport_SX
