Looking for a 3d printed AT101 spacebar file.
gipetto
07 Feb 2021, 21:27
I was an idiot and washed mine in hot water and warped it. I figure someone might have made an stl of one as they seem to be a common failure point.
TNT
07 Feb 2021, 22:05
I have 2 7u Alps spacebars from different boards, so different kinds of stabs, unfortunately. You think one of them might fit?
gipetto
08 Feb 2021, 12:04
No, fairly sure mine is 6.25. Mine is still usable but it jams occasionally. When i attempted to straighten the key it cracked so i reinforced the crack with hot glue. Mine looks like the bottom style with two barrel posts, if i chopped the key down i would lose the stab bar.
