You are on the right path. From my experience, the best cleaning product for glue, grease, grime, solder flux, is Isopropyl alcohol. Also it does not affect the plastic. I you recommend to first try it in a small patch to see if it has undesired effects.
Regarding the rust, there are a lot of diy methods and combinations of substances: wd40 and scrubbing (pretty aggressively), citric acid and hot water, Borax and lemon juice mixed together to form a paste, etc. As with Isopropyl alcohol the best way is to try them out before on small areas to see the results.
Need help with restoring
- kbdfr
- The Tiproman
- DT Pro Member: 0010
This is once again a "copy and paste" (although this time somewhat edited ) of an older thread:wegiwana wrote: 19 Feb 2021, 08:34 So I have recently gotten a model F XT...
What should I use to remove the rust and the glue from the mounting plate? I am pretty sure that scrubbing away the glue, and a "coke bath" would certainly do the trick I'd like to use well... More "gentle" methods. When it comes to removing the glue I was thinking about some isoprophyl alcohol and to remove the rust I was thinking about use some kind of sodium hydroxide (baking soda and water?).
viewtopic.php?f=2&t=18085
(reported)
