IBM 1394104
pgru
11 Apr 2021, 18:25
Hi and thanks in advance for reply
My keyboard of daily use is IBM 1394104, maybe You known more about it?
How looks part of keyboard is in attachment.
pgru
12 Apr 2021, 09:19
So it is even rare there (no reply)? Quite amazing that "stock IBM" keyboard can be little or no known on the Internet...
Rayndalf
12 Apr 2021, 09:28
Do you have a better picture of it? It looks like an ISO M122 with 2-3 different sets of keycaps mixed together.
12 Apr 2021, 09:53
Indeed. The colours all clash. Likely [wiki]frankenboard[/wiki].
Mix enough things together, and whatever you get will be “literally unique.” Not to be confused with noteworthy, however. ;)
Palatino
12 Apr 2021, 10:38
Muirium wrote: 12 Apr 2021, 09:53 Mix enough things together, and whatever you get will be “literally unique.” Not to be confused with noteworthy, however. ;)
Same for genes and people ;)
pgru
12 Apr 2021, 12:21
Nearly whole(excluding terminal connector) keyboard photo:
BTW: what are the official names for this keysets?
Weezer
12 Apr 2021, 18:33
That's a regular M 122 from Greenock with a special order keycap set on it and several random replacement keys.
pgru
13 Apr 2021, 10:52
Thanks for reply. Is the cleaning of keycaps with den. tablets a good idea? Just asking because they show some signs of heavy usage, and don't want to make them blank...
feltel
13 Apr 2021, 13:44
It sould be safe to put the caps into the dish washer as long as you dont use the highest available temperatures. Wearing them blank is nearly impossible due to the process the caps were made.
