mystery calculator switch [Magnetic Reed]
zrrion
22 Apr 2021, 07:59
Seller says they purchased these switches loose in a mason jar, so IDing them is unlikely unless I stumble upon them independently.
It is a very tall, cap is thick doubleshot, and the reed's return chirp is very loud. No idea what the screws on the top are for as they don't screw into anything or hold anything down.
Rayndalf
22 Apr 2021, 12:58
The keycap remind me of this https://www.ebay.com/itm/202814834933?
But the switch mechanism is different. Definitely looks like it's from a calculator, typewriter or a control panel of some kind (basically anything that isn't a conventional computer keyboard).
Edit: 'RM' is a pretty common key on calculators.
s-l2000 (16).jpg (179.98 KiB) Viewed 1934 times
