Interest Check - PDF scans of IBM keyboard templates
Weezer
05 May 2021, 20:48
I have about 5 templates/keyboard manuals that go to various IBM keyboards. I don't think these are available online but I wanted to do an interest check before I scanned them all in.
Shown are:
1. German 3178 manual that slides into the 3178 "blue switch" keyboard
2. textpack 4 template for displaywriter keyboards
3. 3278 maintenance manual that goes in the flap on 3276, 3278, 3279 keyboards, for troubleshooting steps on a 3278 terminal
4. textpack 6 template for displaywriter keyboards
5 keyboard template (unfortunately I only have the one card) for 5251 keyboards
6. keyboard template for 5280 "beamfoot" keyboards.
If you're interested, reply with the templates you'd be interested in and I'll post a PDF scan of it in 600dpi
Weezer
05 May 2021, 20:59
FYI: if no one is immediately interested, but someone finds this years later, the offer will still stand.
Not pictured, but I also have the displaywriter system information card, that gets glued onto the keyboard.
hellothere
05 May 2021, 21:21
I'll say "thanks" in advance! If I ever have a beamspring, this would be a good resource.
Weezer
05 May 2021, 21:33
hellothere wrote: 05 May 2021, 21:21 I'll say "thanks" in advance! If I ever have a beamspring, this would be a good resource.
Well you're welcome...in advance!
I also have the word perfect template for Model F and the template that goes around the Model M F keys to add F13-F24 if you want, but those are pretty common I think.
fabs0
24 Jul 2021, 03:33
Awesome, just what I was looking for :)
Could you provide me a scan of the 5251 template and the 5280, cover page?
Thanks buddy!
Weezer
24 Jul 2021, 04:31
Yeah sure can. So you don't want the whole 5280 booklet, just the first page?
fabs0
24 Jul 2021, 08:28
First page would be enough, want to change it to a 5251 cover page!
Thanks, appreciate it!
Weezer
24 Jul 2021, 11:30
Sounds good! Here ya go. Just keep in mind that the 5280 template card is 7mm longer on the Y axis.
The real life measurements of each card are:
5280 - X= 28mm Y= 4.5mm Z= approx. 2μm
5250 - X= 28mm Y= 3.8mm Z= approx. 1μm
I've also included a mostly blank 5280 card for you in the scan in case it helps with scaling - it's the rightmost card. However the 5280 cards wont fit in the 5251 keyboard template notch at their current size, they'll need to be photoshopped down by 7mm.
Additionally the sysadmin who ran the system/34 I got the 5250 template from had the following penciled in as user defined S/34 commands:
1 Search
2 Single Record Replace
4 Load DE/RPG Tabs
5 Lower Case
8 Copy Data
9 Move Data
10 Delete Lines
11 Set Tabs
12 Add Records
14 Global Replace
20 Shift Data Over 80
Probably not helpful to you if you're looking to print your own command shortcuts, but it might be helpful if you're looking to create something that would be realistic to the time.
Let me know if you have any other questions.
command cards.pdf
(2.78 MiB) Downloaded 175 times
fabs0
24 Jul 2021, 12:03
Nice! I can definitely work with that, thanks.
I just started my 5251 restauration and the inlay will be the last step, so it might take a few days to report back with results :)
shine
25 Jul 2021, 10:48
i have 2 new 5251 templates from my terminals if needed
fabs0
26 Jul 2021, 12:02
shine wrote: 25 Jul 2021, 10:48 i have 2 new 5251 templates from my terminals if needed
Whoa, would you scan and/or sell them?
inozenz
26 Jul 2021, 12:39
Uhh i would need 1 if you sell them :P
karlmartin95
26 Jul 2021, 14:57
Want all please
Weezer
26 Jul 2021, 18:23
Would you be able to scan the 5280 documentation we talked about?
superfoil
26 Jul 2021, 19:59
I would absolutely love scans for any and all of the templates, especially the 5251 templates. I would really like to get a definite answer of the font used on the keys. I believe it's a Helvetica variant, but the scans would allow for a full transcription.
-Space-NATO-
26 Jul 2021, 20:45
yes yes yes
ifohancroft
27 Jul 2021, 13:32
superfoil wrote: 26 Jul 2021, 19:59 I would absolutely love scans for any and all of the templates, especially the 5251 templates.
Same.
