I cleaned the barrels and sliders in an ultrasonic cleaner and put some case foam in there just to experiment a bit. Other than that I didn't do anything.
Only possible explanation I have is that the plate doesn't push hard enough against the PCB or the other way around. I did tighten the screws quite thoroughly tho..
Does anyone have an idea how I could fix that?
