Troubleshooting a malfunctioning PCB
Mindspider
19 May 2021, 21:52
Hello all,
The top row of my keyboard recently started malfunctioning, and I could use some help troubleshooting. Each key is activating the column of keys below: ESC also activates Tab/Caps/Shift/Ctrl, 1 also activates QAZ, 2 activates WSX, etc. My PCB is a DZ60RGB-ANSI v1 hotswap from KBDfans. No known cause of damage: no drops, no spills, haven't moved the keyboard recently.
I took apart the board and did not find any obvious damage or bad solder joints. I tried flashing the board several times, which did not fix the issue. Any suggestions?
shallot
19 May 2021, 23:42
Sounds like you have a short somewhere near the controller if it's happening on all columns.
Mindspider
20 May 2021, 21:31
Thanks for the reply. Is there a way to identify and repair a short like that, or should I expect to need to replace the PCB?
