Hak Foo wrote: 11 Sep 2021, 20:12
This is my perspective:
* I never got the whole switch cracking/lubing/modification thing. Especially today, when there are a bazillion variants (especially of linear and tactile MX-mount switches), won't you get more predictable results, with less risk of breaking switches and losing parts, by just buying a switch that's how you want it STOCK?
* Assuming the "GK61" is the ~$60 hot-swap kit board, what do you need the clippers for? It doesn't look like it has through hole diodes to have to cut.
* If we saw an itemized list, I'm suspecting there are places that you could economize more. What switches and keycaps are you using?
Your total is actually not that outlandish. If you start to get stuff custom cut, the price really jumps. I paid like $150 for the plates for my current board ALONE. Admittedly, it is a 120%, but with zero economy of scale, the prices are brutal.
Jesus Christ!
I'd like to modify the Redragon Kumara RGB later so i need wire clippers to mod the USB C thing ya know.
(and clip stabilizers)
(Sorry in advance if i did not understand something I am Hungarian)
I went for Gateron Optical Silvers which are not smooth switches stock so i want to lube them open up apply 205g0 and close, done!
https://www.banggood.com/104-Keys-Milk- ... mds=search
Milky translucent pudding keycaps.
https://www.banggood.com/70Pcs-or-pack- ... &ID=556698
Sliver switch if it is the wrong link (can't tell)
I might post an itemized list but in this post it doesn't fit
