WTB - a handful of Matias Quiet Click and/or Dampened Alps switches
Palatino
28 Sep 2021, 13:09
Does anyone have some loose Matias Quiet Click switches kicking around? Just 5 or 10 would be fine, either to buy or borrow. These have a mixed reputation but I’m interested in trying a dampened alps-type switch. Even just the sliders would be good, as rather than soldering these I’d like to stick the Matias sliders inside a black or white alps switch housing for a softer feel and sound (maybe both will be worse!)
I know dampened alps switches rely on a different housing design to dampen the downstroke, with large nodules to meet the rubber in the side of the slider, but I’d also be interested in a handful of these to swap into regular alps housings to see what they feel like - and at least the upstroke would be dampened. Again, happy to have just sliders removed from a switch if that saves on soldering!
Thanks.
28 Sep 2021, 13:45
I actually might. They’ll be early ones though. Dunno if they changed them.
thefarside
28 Sep 2021, 15:09
I don’t have the quiet click but I do have the linear version which appears to be the same as the quiet click except for the click leaf being different.
Shoot me a PM if you’re interested. I purchased 200 but only need half for my project and have plenty to spare.
Palatino
29 Sep 2021, 00:28
Thank you - will do!
Palatino
29 Sep 2021, 00:30
Muirium wrote: 28 Sep 2021, 13:45 I actually might. They’ll be early ones though. Dunno if they changed them.
And thank you too. Let me know if they turn up. Your parts shelf/drawer/cupboard is bound to be neater than mine. I can’t sneeze without knocking over a ton of miscellaneous keyboardery.
29 Sep 2021, 15:47
Okay so I have rummaged and I have found… 3—THREE—uno dos tres…damped Matias switches. I'll go take a pic. They're actually linearised damped clicky Matiaseses. Someone else did it, and handed them out at a meetup at GitHub HQ some years back. Got the matching click leaves too.
Are 3 enough? All I've got. Thought I nabbed more, maybe I did but I don't still have them.
Here are ze piques:
What you see here is 4x regular clicky non-damped Matias switches, 2x salmon complicated tactile Alps, and 3x hand linearised damped Matias switches, with their original click leaves in a bag.
Computer: enhance!
Note the telltale white dampers within. That's the nice thing about Matias using clear plastics. You can see what's present and what's missing.
I can probably spare those salmons if you need them.
Palatino
29 Sep 2021, 23:57
Amazing! I wasn’t salmon-fishing, but if you’re offering, I’d love to try them too. And gosh, it’s getting a bit Marks & Spencer with these adjectival strings: [cue oozing music] “These are not just switches… these are hand-linearised damped clicky Matias switches.” Let me know what I owe you for the fruits of your rummage. Those sliders may be dampened but my enthusiasm isn’t! (Had enough of Matiasome humour?)
30 Sep 2021, 13:23
I can just about bear it. Though your determination almost Edgars belief! :roll:
Might as well chuck the lot in a bubble mailer for you. I've nothing lined up for any of them. Already got a salmon in my switch tester stash I think. They're just a random assortment of leftovers from days old.
Return to “Want to buy”
