Dye Sub Sheet for Unicomp Keycaps
JCMax
08 Jan 2022, 05:49
I am going to get blank key-caps from Unicomp so that I can dye-sub them myself with custom combinations. However, I still want to use the same legends and fonts that are found on the Model M's and Unicomp keys.
Where is the best place that I can find these sheets?
08 Jan 2022, 10:46
Custom dye-sub? One of my favourite things!
As for matching Unicomp's own legends: a bit of trial and error seems appropriate! They use a variant of Helvetica. And everything about their alignment is arbitrary / done by hand.
JCMax
08 Jan 2022, 23:49
Thanks! What are some of the best places you could recommend to go looking to buy some?
09 Jan 2022, 11:52
Search on Etsy for dyesub. Here's one:
https://www.etsy.com/uk/shop/Kenykeycap ... 1083747681
Etsy's braindead login captcha system has frozen me out so I can't find the name of the guy in Japan I bought mine from, years back. Some hard to search for name like Good or Nice Keyboards I think.
Edit: here we go. Searched DT instead. DecentKeyboards.
https://www.etsy.com/uk/shop/DecentKeyb ... ng_details
