IBM Displaywriter 6580 Information Card / Sticker
Dionea
22 Jan 2022, 19:01
Recently acquired a Displaywriter 6580 "White Whale", unfortunately with no information card. There is another topic for printing the info cards, however not for the 6580: viewtopic.php?f=2&t=25726
So I decided to re-create as a vector image to ensure a sharper print.
Based on some research comparing pictures, I think that the glued stickers usually were white; the cardboard information cards were grey. The grey colour appears printed (so with half-tone pattern) and the original was not grey paper. However someone with the real one could keep me honest here! There also might have been different versions.
I printed the card with a colour laserprinter using 300gr paper; also used an edge cutter for the corners. The result is very decent, see picture.
Attached the PDF's (both grey and white version) in case anyone is interested. It has cutting marks; print using no margins on A4 (otherwise the print will be smaller)!
IBM 6580 Info Card White A4.pdf
(1.31 MiB) Downloaded 191 times
IBM 6580 Info Card Grey A4.pdf
(1.31 MiB) Downloaded 171 times
shine
22 Jan 2022, 23:25
thanks! this is awesome
Weezer
05 Feb 2022, 06:00
Awesome work
Erderm_
05 Feb 2022, 07:50
Thank you! Gonna get one printed for mine 8-)
tiltowait
27 Feb 2022, 00:40
Dionea wrote: 22 Jan 2022, 19:01The grey colour appears printed (so with half-tone pattern) and the original was not grey paper. However someone with the real one could keep me honest here! There also might have been different versions.
While I might have to use a loupe to be sure, my sticker does not appear to be half-tone. However, mine has a small chip on one edge (it's definitely an indentation, not crud that's stuck to it), and the material beneath is bright white.
Dionea
27 Feb 2022, 21:57
Thanks for the confirmation!
It looks like the same colour as the serial number sticker at the bottom.
So perhaps some versions were made in the command-card cardboard style and the muddy green coloured ones in two-colour print.
I'm going to try printing with grey-olive colored paper.
tiltowait
28 Feb 2022, 00:24
My serial number sticker on the chassis bottom is different. It's a shiny silver rather than a dull gray. See the attached photo. (The angle is funky, because when I took it, I was trying to capture the faded writing.)
Dionea
28 Feb 2022, 21:03
Thanks for sharing! Mine was made in Italy and the label looks green-gray; more like the info card you showed.
