Discovered by Daniel Beardmore (If you don't know him, he runs the website https://telcontar.net/ - I really suggest checking it out. He has done a lot of great research into switch types and manufactures)
It's an old Alps advert showing so called "diaphragm switches".
Has anyone seen these switches in the wild before?
Unknown Alps diaphragm switch
- Lalaland124
- Main keyboard: 3278
- Favorite switch: Beamspring
- zrrion
- Main keyboard: F122
the advert says itself that those are KCC switches, which is the 3 letter designation for SKCC which is a switch you can find all over the place.
However, KGF, KGL, KCF, and KED are listed and those I am not familiar with. Seems beardsmore doesn't have examples/pictures of them either
- Lalaland124
Yess those are the ones we're searching for. Beardsmore sent me the advert and as of right now there seems to be no picture of them anywhere like you said.zrrion wrote: 27 Jan 2022, 07:56 the advert says itself that those are KCC switches, which is the 3 letter designation for SKCC which is a switch you can find all over the place.
