How old is my G80?
Kattun
20 Feb 2022, 19:11
I was surprised to find it with an old ESCOM 486 pizza box that I bought from the classifieds.
I found the page about the "Cherry date codes", but this thing has none.
Double shot keycaps, MX blacks, XT/AT switch, seems in good shape. "made in West Germany" indicates it's pre unification.
Did it roam with the dinosaurs? :shock:
photekq
Cherry Picker
20 Feb 2022, 19:16
Kattun wrote: 20 Feb 2022, 19:11 Did it roam with the dinosaurs? :shock:
You're correct in your guess!
Going by the rear sticker and the style of flip-out feet, this model precedes their date code system. I would guess it dates back to sometime in 1987.
Kattun
20 Feb 2022, 19:44
Thanks for the quick reply, photekq!
Those flip-out feet, well, they do make some sense but I dare anyone to flip them out without fearing to break them. They need to bend quite a bit to unlock from the rear. And the rubber pieces tend to wander.
Other then that, it's pretty solid.
This is so cool - the Tastatur wasn't even part of the deal, I just wanted that old desktop. (Which is gorgeous, btw.)
My first G80 - tbh, the linear switches are kinda boring. And rather stiff, for not being a mechanical typewriter. My parents had a G81 back in the day, which obviously ruined Cherry for me.
Used to borrow a model M for some time. Now, that was a statement ;)
Myoth
20 Feb 2022, 19:51
To add a bit to this thread, if you're still in possession of that keyboard, you could probably open it up and get a precise dating of it. Either the case will be dated, or there will be an explicit date written somewhere. If all fails, you can get a lower bound by checking the ICs on the PCB.
photekq
Cherry Picker
20 Feb 2022, 19:54
Kattun wrote: 20 Feb 2022, 19:44 Those flip-out feet, well, they do make some sense but I dare anyone to flip them out without fearing to break them. They need to bend quite a bit to unlock from the rear. And the rubber pieces tend to wander.
You know, I actually prefer those old-style flip-out feet when it comes to using them. But I can understand why Cherry redesigned them swiftly; I've got no doubt that they had some complaints about them breaking. There's a bit of a knack for pulling them out, it's hard to describe. I've flipped mine backward and forward countless times with no issues.
Kattun
20 Feb 2022, 20:03
Myoth wrote: 20 Feb 2022, 19:51 you could probably open it up and get a precise dating of it.
thanks - I know, there usually is some kind of stamp on the PCB.
Alas, I tried that earlier today and aborted mission because I coudn't quite figure out how to safely do that. It's a combination of four screws up front and some hook on the rear, the latter remaining opaque.
I may try again once I have more leasure for such things.
VexSolar
20 Feb 2022, 21:12
Kattun wrote: 20 Feb 2022, 19:44 Thanks for the quick reply, photekq!
Say, if you believe the linears are boring, I'll gladly take them off of your hands :D
Kattun
20 Feb 2022, 22:09
VexSolar wrote: 20 Feb 2022, 21:12 Say, if you believe the linears are boring, I'll gladly take them off of your hands :D
... haha, and you're not even the first to ask :P
At least give me some time to actually try the thing out, you vultures! I might even aquire the taste?
It's not a G81, I can tell that much!
I'm simply used to some tactility.
I might have considered shelling out three figures for a good MX blue piece, were it not for the tendency of my keyboards to look like Dresden '45 after some time, it would be a shame.
So for now, I'm sticking to a sturdy black IBM rubber dome I got NOS for a fiver. Which is actually not all that bad.
VexSolar
20 Feb 2022, 22:12
Kattun wrote: 20 Feb 2022, 22:09
Sounds good. But if your taste for them never develops... you know who to call :lol:
