A friend can lend me an ultrasonic tank to clean the keycaps (and stems). Which cleaning agent is better to use? Is there a specific one or is a domestic one enough?
How long would it take to clean the keys? It is a 2.5l tank, 160W power.
Thanks in advance.
Cleaning agent for ultrasonic clean
- TNT
- DT Pro Member: 0250
I always use tap water and add some dish soap. No experience with those fancy cleaning agent products, but said combination always did the job for me
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
Usually denture cleaner tabs, two per load. If they look especially nasty, Simple Green + water.
Also, if it's your first time doing this, check to make sure that it's not too hot. I've melted some pad-print caps at 50C.
- TNT
Yeah, totally forgot. I do that too if it's necessary, but didn't have to in a long timehellothere wrote: 24 Feb 2022, 15:47 Usually denture cleaner tabs, two per load. If they look especially nasty, Simple Green + water.
- Main keyboard: F122
- Main mouse: MX Master 3
I've had good results with Harbor Freight's ultrasonic cleaning powder:
https://www.harborfreight.com/6-oz-ultr ... 91593.html
In my experience it works much better than just water alone. It has perfectly cleaned all but the very grimiest of keycaps I've used it with.
