Advice to buy ultrasonic tank
caberolo
20 Mar 2022, 23:44
Hello everyone.
I'm thinking of buying an ultrasonic tank for keycap cleaning. What capacity, power and temperature would be advisable? I have seen many second-hand ones in the €25-70 range, with a capacity between 0.6 and 2.5l, and between 50 and 150W. On amazon, I have seen comments that those with low capacity and power are only good for very small things, being unable to clean an ink injector, for example.
What features do you recommend it have?
Best regards
hellothere
21 Mar 2022, 23:01
viewtopic.php?t=17208 is probably the most comprehensive thread on the subject. I recommend searching Google for "deskthority" I'm thinking of buying an ultrasonic for keycap cleaning and you can also substitute "geekhack" for "deskthority."
A lot of the links to the actual equipment to purchase are a tad old. I suppose we could share what we currently have.
