Monotype E11L - The largest keyboard I have ever seen.
System
19 Apr 2022, 10:04
Hey! I have 2 of these massive in size interesting keyboards, They seem very rare as through my searching I'm the only one who has any of these kinds. Here's some info I have gathered from my keyboards:
- Has 186 keys in total on one board.
- Has a futura legend on the keycaps.
- Has 2 space bars.
- Not in a standard format for keyboards
- Includes every single possible key known to mankind such as umlats and double ff's for some reason.
- The key caps are replaceable by adding different card letters under the plastic pieces.
- The keys themselves are magnet and some kind of leaf spring based ( Similar to alps).
- The keyboard case is made from what it seems like solid lead and weighs about 5kg in total.
These keyboards are originally from monotype typesetting (A type of machine for making fonts) machines (Room sized) with the model of the machine being unknown for these keyboards. Because of the nature of these keyboards they have no interface to plug it into computers or any interface on them. The keys sound generally very thocky due to the case of the keyboard being solid metal.
Heres some technical specs:
- The key caps are not staggered at all but have a height of 15mm.
- Total thickness of the board is 50mm.
- Width of 5mm between keycaps
- The dimensions are 380mm by 350mm
I will add pictures to this post for you guys to bask in the glory of this monster of a keyboard. Also does anyone know what something like this would be worth to a collector of a keyboard? :?:
19 Apr 2022, 11:25
Typesetting is the opposite of designing fonts, it's the process of actually using them. ;)
Monotype was one of the main systems for commercial printing. Their keyboards always looked quite like that. Here's a pre-digital 1965 model from Wikipedia:
The operator would lay out the final text, line by line, by hand on that machine, looking after all the hyphen-ations and line breaks etc. we're so used to being handled automatically on computers. It's slow, precise work. What they're actually typing winds up in metal and then on thousands of copies in the press.
Pretty cool find. They're fairly rare, as only a commercial printer would have one of these machines.
System
19 Apr 2022, 11:41
Muirium wrote: 19 Apr 2022, 11:25 Typesetting is the opposite of designing fonts, it's the process of actually using them. ;)
This one in the picture is an early model, I believe mine to be one of the last models they seemed to made before going all digital but just can't place a timeframe as nobody knows where and when it came from.
19 Apr 2022, 12:09
Pull some caps and look at the switches then. We should be able to identify them. ;)
System
19 Apr 2022, 12:40
Muirium wrote: 19 Apr 2022, 12:09 Pull some caps and look at the switches then. We should be able to identify them. ;)
The picture I've added of the internals are the furthest you can take the switches apart as the magnets and other components are sealed in plastic and metal casings. No identifying marks on the springs or internals apart from the monotype branding
19 Apr 2022, 13:53
You mean this?
You removed the cap on the key beneath C? Show us the underside of the cap, that can help too.
19 Apr 2022, 14:17
Most keys I know of on one keyboard is the Accom Axial; 189.
Pretty sure it's also a lot bigger.
Biggest and heaviest keyboard I know of is the Berthold mothership keyboard, though. Dwarfs even a battleship.
19 Apr 2022, 14:44
Biggest and heaviest board I've seen was a small collection of truly massive Xerox metal chassis keyboards in storage at the Museum of Communication. I'll see if I posted pictures. The closest the Wiki has is:
wiki/Xerox_928-900451
Oh, here we go: Digibarn's got the whole system: Xerox 860 IPS
Monu-MENTAL-ly mahoosive magnificently majoritarian magnum opus Do Not Drop Will Kill keyboard. The whole exterior is metal. Makes my 3278 beamspring seem like an SSK in comparison.
Linear, of course. Rings a fair bit, as I recall, but at a profoundly deeper pitch. If the M0110 is the Ukulele, this thing's the contrabass.
Also noteworthy: the "CAT" touchpad. So futuristic!
19 Apr 2022, 14:54
Don't forget about the Alps Kanji monster with 542 keys at a staggering 11.92 kg. There are rumors of even larger keyboards from long ago in the age of dinosaurs.
viewtopic.php?t=21937
19 Apr 2022, 15:04
Defo area champion. Looks a bit svelte on the desk, though:
Sure you aren't just one of those egregious compact keyboard posers? ;)
jsheradin
19 Apr 2022, 15:05
JP! wrote: 19 Apr 2022, 14:54 Don't forget about the Alps Kanji monster with 542 keys at a staggering 11.92 kg. There are rumors of even larger keyboards from long ago in the age of dinosaurs.
Love the ring stand holder on the top corner. Presumably it's for a lamp since there's no way a sane person could touch type on that monster.
19 Apr 2022, 15:11
Muirium wrote: 19 Apr 2022, 15:04 Sure you aren't just one of those egregious compact keyboard posers? ;)
Maybe...
In reality I currently have a full-size Lexmark branded Model M on my desk.
19 Apr 2022, 15:27
Fun fact: a 12 × 4 - 1 = 47 key matrix board like that has 47! = a very large number indeed of possible combinations, if you chord hard enough. Just keep using more fingers and you can easily exceed that kanjichameleon.
Or if you're truly limited to 10, then yeah it's just 5.178 billion.
Even only 2—TWO—damn fingers, will give you 1081 effective keys, on an itty-bitty forty! 1770 on my luxuriously large HHKB here.
jsheradin wrote: 19 Apr 2022, 15:05…there's no way a sane person could…
Where we're going, you won't need "sane."
19 Apr 2022, 15:35
Muirium wrote: 19 Apr 2022, 15:27 Just keep using more fingers and you can easily exceed that kanjichameleon.
System
19 Apr 2022, 15:58
A more ergonomic massive keyboard :o
System
19 Apr 2022, 15:59
Muirium wrote: 19 Apr 2022, 13:53 You mean this?
That's the top of the switches see the 3rd picture for the underside / spring. :D
19 Apr 2022, 16:39
All of that is nice stuff, sure, but this is a fully functional keyboard which has been my daily driver for more than 10 years:
Tipro, of course :mrgreen:
Don’t tell me you did not expect this :lol:
19 Apr 2022, 17:51
Oh man, how could I forget the Yamato Kanji keyboard! Truly a sight to behold! :D
System
20 Apr 2022, 18:51
I have also made a sound test of the monotype e11L https://youtu.be/J7DantP4Ozw just to show how it sounds.
Lalaland124
20 Apr 2022, 19:20
System wrote: 20 Apr 2022, 18:51 I have also made a sound test of the monotype e11L https://youtu.be/J7DantP4Ozw just to show how it sounds.
Damn, this sounds indeed very thoccy :D
Do you have any more information on the switches?
System
20 Apr 2022, 20:10
Lalaland124 wrote: 20 Apr 2022, 19:20
None at all I'm the only person with info on this model online
SOTGO
26 Apr 2022, 20:20
Chyros wrote: 19 Apr 2022, 14:17 Most keys I know of on one keyboard is the Accom Axial; 189.
Don't forget the 510 key keyboard that went with the PolType-04. Marcin Wichary posted about it in one of his book updates here: https://www.getrevue.co/profile/shift-h ... t-3-190876
BEEDELLROKEJULIANLOC
04 Jul 2022, 01:48
kbdfr wrote: 19 Apr 2022, 16:39 All of that is nice stuff, sure, but this is a fully functional keyboard which has been my daily driver for more than 10 years:
Which model of keyboard is that?
04 Jul 2022, 06:30
BEEDELLROKEJULIANLOC wrote: 04 Jul 2022, 01:48
Tipro is a manufacturer of modular point-of-sale equipment, including fully programmable keyboards.
This one is composed of 3 keyboard units (of their discontinued MID range), with a 8x8 matrix module on either side coupled with a (modified) staggered module in the middle.
It features Cherry MX black switches and, of course, still flawlessly works like a charm after all these years.
