Visual Technology Keyboard Convert
retrocatgaming
- Main keyboard: Cherry mx G80-8200
- Favorite switch: Amber Alps
Came across this visual technology keyboard and I’ve been working on trying to create a converter so I can use it on a modern PC. Connected it up to a soarers logic analyzer and used HID listen to detect key presses. (detects all keys btw) and I think, although I’m not 100% sure, it’s sending data over serial. Came to this conclusion from the readings that I got from using soarers logic analyzer and PulseView. I got as far as trying to figure out baud rate, which I want to say is 600 baud according to measurements I made on the shortest pulses in the trace but I can’t be certain. I’m not very well versed in this sort of thing so basically I’ve hit a roadblock. Hoping someone here could lend me some insight on what to do next to get this thing converted!
- 4F37310A-3007-4AAD-AB33-5884AA337294.jpeg (2.78 MiB) Viewed 2091 times
- 88E1F992-7D71-47CC-8104-BDDBF18307E4.png (209.17 KiB) Viewed 2091 times
- F58034E5-36DF-4721-A11F-1040ACC31379.jpeg (3.24 MiB) Viewed 2091 times
- 677391CC-3A69-46EB-A85D-23D10CC5B08E.jpeg (4.2 MiB) Viewed 2091 times
