[DE - INT] Nick´s "Keys to the Past" - new stuff
guidemetothelight
20 Apr 2023, 10:14
LAST PRICEDROP FOR THE CURRENT STUFF
Will ship internationally, Paypal is the preferred payment option.
I always update this thread with stuff I no longer need / want to get rid of.
If you have any questions / need more images , just ask :)
up for grabs
reserved
sold
IBM Model F XT - 145€
Overall in great condition, no scratches or broken pieces. Case is non original, since the older one had defects. Keycaps have been swapped with an early Model M, since it started life out as an azerty board. Feet work great, cable is in great condition and has zero sticki-ness.
modelf
modelf
XT + Wheelwriter Project - 35€
Selling my almost complete wheelwriter xt project to someone who is willing to finish it or can use the parts. Case has a small crack & a small bit that chipped off on the lower right hand corner. (Didnt bother me, as you cant see it while using the board)
Wheelwriter plate has been cut to size, all rivets removed & the cracked barrel plate repaired.
Comes with a full set of springs & flippers, keycaps, stabilizers and screws to screw mod the plate. Only needs a controller & some time.
Build instructions can be found in SunshineRags Post
Lauer Fischer G80-1800 - 18€
fixed black usb cable. lasered keycaps. mx black.
i had 3.
Viktor 286 / Alps SKFN - free
Triumph Adler 600 DS Keycaps - 30€
Thick PBT Dye Sub Keycaps with beautiful two tone blue colouring.
MX compatible.
Cherry HAD Keycaps - 85€
Great condition. Very close to no shine at all. Have been deepcleaned since I took the photo. Without the G81, only caps. Full Set.
Cherry HAD Numpad - 10€
3D printed Numpad with modern MX Browns,
Stabs are horrible and the thing flexes a lot
numpad_front
numpad_front
closeup
closeup
switches
switches
backside
backside
numpad_back
numpad_back
Apple Desktop Bus Keyboard - 80€
Cleaned everything but the Switches themselves.
Orange Alps - 8/10
Could use a retrobright, which is fairly easy with this Model, due to the fact that the case can be easily disassembled into 2 small and one larger piece.
Ducky One 2 Mini - 35€
Ducky One PCB, plate + stabs, case is a low profile 3D-printed PLA case in white, switches are (vintage?) MX Blacks from a pre 2000´s Cherry G80 1800 HAD. I cant tell for sure that they are vintage, but they feel quite nice.
Keycaps should be blank black PBT, since they feel quite textured. Keyboard is also foam modded and the stabs have been slightly lubed.
Profex TD 1000 - 35€
profex1
profex1
Cherry MX Clear
Cherry MX Clear
Profex Label
Profex Label
IBM Model M - 75€
Detachable PS2 Cable. Good condition, but may need some cleaning of the keycaps.
Chicony 5182 - 40€
Good condition, but may need some cleaning of the keycaps. Cherry MX (blue). Case has some yellowing towards the bottom.
Apple M0118 - 45€
typing test for sound
slight yellowing of the case and spacebar.
I got this at a meetup.
Switches have been robbed swapped with Matias Clicks by previous owner.
Comes with an ATmega32U4 based ADB to USB converter, but some keys dont register.
Since I dont like the layout, I will sell it to someone who wants to tinker with it ;)
Alps SKEW 75x - free when you take something else
Ortek MCK-101FX - 40€
Ortek MCK-101FX
Ortek MCK-101FX
Keycaps removed
Keycaps removed
[/attachment]
HHKB Professional 2 - 160€
New & unused. Just took it out of the box for typing a few sentences & for pictures.
Sharp XQ-380 Keyboard Module - 60€
The Keyboard Module from a Sharp XQ-380 Typewriter. Comes with Alps SKEW and very nice, Double-Shot Caps
Canon AP 150 - free when you take something else
maxgpdx
23 Apr 2023, 00:18
Pm’d about the sharp
ntv242ver2
24 Apr 2023, 12:29
guidemetothelight wrote: 20 Apr 2023, 10:14 Iam looking to sell some Stuff.
Open for negotiation. I will add some stuff / images later.
IBM Model M - 95€
HHKB Professional 2 - 170€
New & Unused. Just took it out of the box for typing a few words & for pictures.
Ducky One 2 Mini - 60€
Ducky One PCB, Plate + Stabs, Case is a low profile 3D-printed PLA case in white, Switches are (vintage?) MX Blacks from a pre 2000´s Cherry G80 1800 HAD. I cant tell for sure that they are vintage, but they feel quite nice.
The Keyboard Module from a Sharp XQ-380 Typewriter. Comes with Alps SKCP and very nice, Double-Shot Caps
Sorry to inform you that, those are NOT SKCP switches, they are SKEW, or two piece alps integrated dome. They are worlds apart, on everything.
guidemetothelight
24 Apr 2023, 13:04
ntv242ver2 wrote: 24 Apr 2023, 12:29 those are NOT SKCP switches, they are SKEW, or two piece alps integrated dome. They are worlds apart, on everything.
Thanks for the Info. Havent sold it under the pretense, its staying in my collection (for now). I´ll correct it either way.
guidemetothelight
04 May 2023, 10:50
added new stuff
Man from Mars
04 May 2023, 13:39
guidemetothelight wrote: 04 May 2023, 10:50 added new stuff
PM'd about the Ducky.
guidemetothelight
05 May 2023, 17:27
added new stuff
-Space-NATO-
05 May 2023, 19:17
PM'd
guidemetothelight
30 May 2023, 10:07
bump
podgen
06 Jun 2023, 11:29
Are those green alps / clones in the ortek?
guidemetothelight
06 Jun 2023, 11:32
podgen wrote: 06 Jun 2023, 11:29 Are those green alps / clones in the ortek?
clones, all FX models come with clones, only SX comes with white alps
podgen
06 Jun 2023, 12:25
guidemetothelight wrote: 06 Jun 2023, 11:32
oh interestinng, I'd never seen that before! Apologies for clogging the sell thread
guidemetothelight
06 Jun 2023, 14:41
podgen wrote: 06 Jun 2023, 12:25 oh interestinng, I'd never seen that before! Apologies for clogging the sell thread
no worries at all !
if I may ask, what have you never seen before ? green alps clones or that particular board with clones :D
podgen
06 Jun 2023, 17:14
guidemetothelight wrote: 06 Jun 2023, 14:41
no worries at all !
a little bit of both haha, i knew green clones did exist but thought that this board had the muchhh more common white clones. How do these feel by the way? something in my brain associates clone with smoothness because of the mx game, but that probably doesn't apply here right?
guidemetothelight
07 Jun 2023, 08:45
podgen wrote: 06 Jun 2023, 17:14 a little bit of both haha, i knew green clones did exist but thought that this board had the muchhh more common white clones. How do these feel by the way? something in my brain associates clone with smoothness because of the mx game, but that probably doesn't apply here right?
Well, the one´s in the Ortek are ok. They are quite smooth, but sound more hollow then the OG greens.
I have 3 green clones in my collection that are all different from one another.
One type from a second Ortek board, one from NTC´s 6251 and one from a seller on ali express that claims it´s taiwan made.
Maybe I´ll add a sound comparison one day.
from left to right: Taiwan Ali, Ortek, NTC, Alps
podgen
07 Jun 2023, 18:12
ohh interesting, i kinda want to start my own switch collection but it'd be hard to resell a keyboard with a missing switch. I've been looking for a linear alps-y keyboard for a whilee now, so I'll keep you in mind if i find the funds
guidemetothelight
09 Jun 2023, 08:26
podgen wrote: 07 Jun 2023, 18:12 but it'd be hard to resell a keyboard with a missing switch.
ahh its not that hard to source switches for a tester. You can replace a singular, sparely used key with an aftermarket one (matias, tai hao apc, other clones) there are typewriters out there with alps switches, you can trade in the community, you can use one if you desolder a complete board but you dont need all of the switches for a custom board. many options to obtain switches :D
09 Jun 2023, 11:18
Does that mean you’re up for making and selling samplers just like this? If you had brown Alps in the mix, I’d be all over it! :D
guidemetothelight
09 Jun 2023, 11:59
Muirium wrote: 09 Jun 2023, 11:18 Does that mean you’re up for making and selling samplers just like this? If you had brown Alps in the mix, I’d be all over it! :D
Probably not, since getting the good stuff (browns, blues, ambers etc.) is next to impossible to do in Germany. (at least with the budget of a 23 year old )
Oranges, salmons, undampened creams and greens are a bit easier, with blacks, (dampened) whites & creams being the easiest to obtain.
Browns aren´t in the mix since the only ones I got are currently in my 5140 keyboard assembly that is waiting to be desoldered and transformed into my custom frog mini build :D
Btw the spacing of the alps keys is so weird , since iam (re)using the cheapo 1.25U blanks that Tai Hao likes to add to to your orders as a gift
TNT
09 Jun 2023, 16:40
Gotta try those browns once your build is finished and you have the chance to bring it to a convention or smth like that. I wanna see what the fuzz is all about
guidemetothelight
12 Jun 2023, 08:29
TNT wrote: 09 Jun 2023, 16:40 Gotta try those browns once your build is finished and you have the chance to bring it to a convention or smth like that. I wanna see what the fuzz is all about
I want to go to another meetup so badly ! I´ve only been to 2 local,small ones .But iam looking forward to see a few online-only faces and get to know the person behind the posts :D I promise to bring my board to the next one I go to
inozenz
12 Jun 2023, 11:12
guidemetothelight wrote: 12 Jun 2023, 08:29
i promise you the small ones are more fun then big ones
12 Jun 2023, 11:26
The smallest meet-up I ever went to was with Haata to his house. Could have spent all day there. Might have been difficult to shift me out. :D
guidemetothelight
12 Jun 2023, 11:51
inozenz wrote: 12 Jun 2023, 11:12 i promise you the small ones are more fun then big ones
Cant speak for big ones but both small ones were awesome !
Muirium wrote: 12 Jun 2023, 11:26 The smallest meet-up I ever went to was with Haata to his house. Could have spent all day there. Might have been difficult to shift me out. :D
Yeah, both of my meetups were with the same people, a smaller dev studio, focusing on ios apps.
The whole company was there (around 25-30 people) and the boss even got food and drinks for everyone.
I was the only external guy, mainly cause I was responsible for getting a good chunk of the people there into the hobby :D
Also because instead of being "normal" like everyone else and bringing 1-3 custom mx based boards , I brought 10 or so vintage boards... and left with 11 :lol:
guidemetothelight
19 Jun 2023, 09:51
bump - added a board
guidemetothelight
01 Jul 2023, 12:09
bump - price drop
guidemetothelight
11 Jul 2023, 18:09
bump - added a board + final pricedrop for old ones
Nuum
11 Jul 2023, 19:01
PM'd about the Apple Desktop Bus Keyboard.
guidemetothelight
17 Jul 2023, 10:53
bump - added new stuff
TNT
31 Jul 2023, 00:30
pm'd
Return to “For sale”
