[CLOSED] - T-mount cherry M7
guidemetothelight
07 May 2023, 14:00
Looking for a single Cherry M7 with the T shaped mount. wiki/Cherry_M7
I want to use the Code Button from my Model 95 IBM for starting up my computer.
A seller from europe would be the best call I think.
TNT
07 May 2023, 16:51
Just out of curiosity: Starting up your computer as in the keycap and switch are connected to the headers on your motherboard? Where are you going to put it?
guidemetothelight
07 May 2023, 23:20
TNT wrote: 07 May 2023, 16:51 Just out of curiosity: Starting up your computer as in the keycap and switch are connected to the headers on your motherboard? Where are you going to put it?
On my desk in a small 3D printed enclosure.
Its for my second pc which is currently residing in a modified mac g5 case.
Sadly the front panel wiring is non standard & I botched the rewire, leading to it not starting up via the power button.
(Got the front USB port to work though :? )
But thats why iam doing all of this.
Already printed a small adapter to mount it to a cherry mx black.
I also modeled the enclosure already , but I had some issues with the stl file not being properly sliced...
TNT
08 May 2023, 00:57
Very nice! Be sure to post the end result, please! Maybe in the Model 95 thread
Return to “Want to buy”
