I'm trying to buy an Apple Extended Keyboard II with Salmon Alps switches. Is there any way to tell if an AEK II has salmon switches based on serial number or some other visual indicator.
Lots of eBay listings, none with a keycap pulled.
- Main keyboard: Apple Extended Keyboard (Salmon Alps)
- Main mouse: Kensington Slimblade Trackball
An AEKII likely has salmons if it has no S in the bottom right on the back label.
- fohat
- Elder Messenger
- DT Pro Member: 0158
Only the very very earliest ones might have salmon switches.
AEK is a far better bet, almost all have either orange or salmon.
- Main keyboard: Drop Alt High Profile
- Main mouse: Logitech M570
- Favorite switch: Glorious Panda
I just bought an AEK with serial number 502XXX that has orange switches. Anything much past that should have salmon switches.
FWIW, I’ve never noticed an AEK II on eBay that doesn’t have the boxed S. Sub-500XXX AEKs pop up every few months.
- LambdaCore
- Main keyboard: HHKB Professional Classic (currently in rotation)
- Main mouse: Logitech MX518
- Favorite switch: Capacitive Buckling Springs
My strategy when I got my m0115 with salmons is to wait until I found one sold as "broken" with a keycap broken off. It's a missing keycap, sure, but when they get stuck in the slider, that's pretty easy to slip out when you take it apart.
I was considering an AEK, but they're pretty pricey and seem to have yellowed way more than an AEK II.fohat wrote: 20 May 2023, 23:55 Only the very very earliest ones might have salmon switches.
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
wiki/Apple_Extended_Keyboard_II. Salmon Alps ones are labeled M3501, made in USA ©1989. Anything else is just a possibility of salmon Alps. I've learned this the hard way.
a. I do have a salmon Alps AEK II that needs a ADB port (as in, it was missing when I bought it). Not restored, yet. Make me an offer. It's currently down fairly far on my "to be repaired" list.
2. I have a bunch of orange Alps that I was going to put in a Dell bigfoot case. Put some non-refundable cash down and I'll start working on it, then you can buy it.
i. I also have a Mitsubishi Mechanical (not miniature) and probably both some white damped and cream damped Alps keyboard. Again, not restored yet.
- fohat
- Elder Messenger
I did that (using the black case, with pseudo-Dolch caps) and it is a magnificent beast.hellothere wrote: 27 May 2023, 17:20
- hellothere
Nice idea. I have this set of double-shot new Tai-Hao Alps keycaps (blue, light blue, and tan) and I think I'll swap out the original pad print Dell/SGI caps for these, too.
I've got three or four bigfoot cases, but they're all cream colored. I know a couple are pretty yellow, so I may paint those granite grey. Those Tai-Hao caps would look really nice with that.
I have several OmniKeys I need to finish, first. I've been slacking and only uploading one or two keyboards a month to ebay.
