Key cap storing and organizing
Limmy
13 Jun 2012, 09:25
Here is how I store and organize my key caps.
I use a filament tape and cut it to x7 of a normal key(about 13cm). For a full sized keyboard, one row of alphanumeric part of the keyboard has size of x15 of a normal key. So, two pieces of the tape is usually enough to arrange a whole row. I am huge fan of 3M adhesives and I have only good things to say about 3M filament tapes. The tape used is 898 and has 1/2in width, but any other filament tape with similar width will do the job just fine. Filament tapes are usually thick and has stronger adhesives, so key caps can be nicely attached and key caps do not move around, even when stored in a bag.
Here are two photos of the usage of the tape.
key cap storing 1
key cap storing 1
2012-06-13 02.56.47.jpg (77.73 KiB) Viewed 12321 times
key cap storing 2
key cap storing 2
2012-06-13 02.58.39.jpg (73.88 KiB) Viewed 12321 times
I think it would be beneficial to introduce other popular methods.
1. key cap paper by Leaf : http://pinchocodia.tistory.com/149 (look for keycap_paper_A4_series.zip)
2. modified key cap paper by Hambok : http://www.kbdmania.net/xe/4044382 (click on Keycap Paper-투톤.jpg)
3. key cap storing box by Seebum : http://www.kbdmania.net/xe/4217192 (this one is from group buy in KBDMania. See pics below for prototype. The final version of boxes will be coated.)
2012-05-30 18.32.15_resize.jpg (150.06 KiB) Viewed 12321 times
2012-05-30 18.26.20_resize.jpg (114.44 KiB) Viewed 12321 times
ripster
13 Jun 2012, 16:34
I just cut cardboard pieces, slap some carpet tape on it, and the toss a bunch of them into a storage box.
Ducky has the NICEST key packaging in the biz.
http://geekhack.org/showthread.php?2963 ... o-ABS-keys
KBC's get kinda goopy, at least the old ones did
And Filco blank key set packaging is nice.
http://geekhack.org/showwiki.php?title=Island:6511
I am hoping Elitekeyboards sells PBT keys separately when the FC700r but is unlikely. At least the last time I checked Leopold they were not selling them separately yet.
http://www.reddit.com/r/keyboards/comme ... eopold_at/
captain
14 Jun 2012, 10:00
hoggy
14 Jun 2012, 14:53
I'm using a mixture of tupperware and as I don't know the name of them - divider boxes.
Input Nirvana
16 Jun 2012, 18:13
I knew there was a better way.....
Half-Saint
21 Jun 2012, 13:46
I'm using resealable labeled plastic bags - one bag per set. Toss it all together in a big box.
CeeSA
21 Jun 2012, 13:51
@Limmy - i like your method and take it for me, thanks
damorgue
04 Jul 2012, 19:03
I had an idea, don't know if it has been done before and I am just rehashing but here it goes.
You know those fly-papers that is essentially a sticky surface that catches flies, most commonly in farms where it is a bigger problem. There are kinds either on a roll where you pull it out as it gets filled with flies and the kind like a calendar where you rip a page of every now and again. Both of these could be used with some success to just place keys on to make them stick in a certain layout and not scrape against eachother. This is sort of a replacement to adhesive tape for those of you who use that.
My only concern right now before having tried this is that they might be coated with a sweet substance attract flies which might get on the keys more than just the mild adhesive could and perhaps make them smell.
Thoughts?
kint
04 Jul 2012, 19:23
Thoughts: the sticky stuff is nasty and sticky as hell [edit: definitely not residue less afair]. I'ld rather go with double sided aka carpet tape.
kalrykh
04 Jul 2012, 19:31
Right now I'm doing the same as Half-Saint. If I know i'll be using one set in the near future or want to stage some to see how they'll look together, I'll use the molded plastic cover that came with a leopold or filco, put the keys where they belong in that upside down, then put some cardboard behind it and flip it over to see how it looks.
JmactheAttack
04 Jul 2012, 22:59
Does anyone have a keycap pdf or image template that can fit all the keys on a standard 8.5x11?
off
05 Jul 2012, 00:13
I was gonna cry about how you didn't even read the OP or searched; but turns out that I can't find it either, not even after searching quite a bit. So, sorry, can't help you..
Funny because originally that was all there was available iirc, and google cache still points to a geekhack attachment containing tsangan's legal sized copy.
Shouldn't be that hard to go from A4 to Legal/Letter with a bit of MsPaint though?
Other option is to wait for someone to dig their copy up from somewhere on their hdd's, but that might take a while.
and thanks all for sharing your methods; mine is currently simply in sealable baggies, but afraid the caps may become DOT'd by throwing those around.
kalrykh
05 Jul 2012, 01:02
the link to the paper is in there with limmy's post
off
05 Jul 2012, 01:06
Thanks for trying!
*edit: No, it is not. He asked for the version to be printed on Legal/Letter sized paper, although he sadly didn't specify that his 'standard 8.5x11' were inches or the likes, that much could still be glanced from his post.
Or my post right above yours for that matter.
kalrykh
05 Jul 2012, 01:51
I wonder if it's possible for you to answer without the snide elitist tone. Pull your head out of your ass a bit.
The closest you're going to get is the A4, which will work if you edit out the white on the left and right sides and are able to do a full bleed print to letter sized paper. If you can do a full bleed, you're fine. If you can't, which I would assume most can't, your best bet would be to print the a4 version on legal paper without telling it to stretch. If you just try to shrink the A4 to fit in a letter sized sheet, which isn't shrinking that much, the printed out caps won't be large enough to accomodate. The method I tried, which was cutting out the white and taking my margins down as low as my printer would allow, _almost_ makes it...but a full row of keys ends up being about 1/4 of an inch longer than the printed version.
off
05 Jul 2012, 02:04
kalrykh wrote:I wonder if it's possible for you to answer without the snide elitist tone. Pull your head out of your ass a bit.
Nope, it's stuck. Possible for you to read before posting? :roll:
I did catch some air though, hence the added explanation.
And, as I mentioned, someone, somewhere, should have tsangan's version for Legal/Letter sized paper. Perhaps tsangan.
JmactheAttack
06 Jul 2012, 20:32
Thanks for the replies, I really didn't try to hijack the post with an ignorant addition, but I really couldn't find anything on Google which is why I asked a specicif. I'll have to see if someone around work has ledger sized paper since I doubt anyone will have the A4. I might end up doing the whole tape two pieces of paper together routine to get the full printout if I can not find any.
Limmy
06 Jul 2012, 23:58
JmactheAttack wrote:Thanks for the replies, I really didn't try to hijack the post with an ignorant addition, but I really couldn't find anything on Google which is why I asked a specicif. I'll have to see if someone around work has ledger sized paper since I doubt anyone will have the A4. I might end up doing the whole tape two pieces of paper together routine to get the full printout if I can not find any.
Legal size(8.5in x 14in) papers are pretty common in the US. I am attaching a PDF printout of keycap layout paper by Hambok.
keycap paper by Hambok Legal.pdf
PDF printout of Hambok's keycap paper for Legal size paper.
(183.62 KiB) Downloaded 414 times
off
07 Jul 2012, 00:01
Awesome Limmy to the rescue! Appreciated.
phetto
Elite
07 Jul 2012, 01:35
I use multiple fishing tackle boxes : :ugeek:
JmactheAttack
07 Jul 2012, 23:28
Legal is very common and as such, I have some and am about to print it out. Thanks!
The_Beast
08 Jul 2012, 04:53
I just use tackle boxes, same thing used to store fishing lures
IvanIvanovich
08 Jul 2012, 05:15
I have been thinking about some sort of plastic thing like a sheet with stems on it to stick keycap on which could be stored while keeping the proper arrangement. Kind of like ripsters way, but without tape that puts sticky junk on the bottom. Sort of like a fake keyboard. Then you don't have to sort or hunt when changing keycaps.
Only thing would probably need to make 4 major type of this in ANSI and ISO both winkeyless and winkey version.
Would anyone else want something like that?
08 Jul 2012, 07:28
lysol wrote:I have been thinking about some sort of plastic thing like a sheet with stems on it to stick keycap on which could be stored while keeping the proper arrangement. Kind of like ripsters way, but without tape that puts sticky junk on the bottom. Sort of like a fake keyboard. Then you don't have to sort or hunt when changing keycaps.
I've been planning and designing something like that for a few weeks now
and came to the conclusions it MUST fit any keyboard layout to secure cheap production AND general acceptance.
And yes, it is possible :mrgreen:
CeeSA
06 Aug 2014, 11:05
I know this is an old thread. But I would like to know your new methods, products or ideas if you know or have some ;)
http://elitekeyboards.com/products.php? ... us104_case
Here is a procduct for ANSI sets.
Is this available for ISO too (although I did not like ISO, I still have some ISO kits)?
06 Aug 2014, 11:36
Signature Plastics offers something similar to what I had planned:
http://keyshop.pimpmykeyboard.com/produ ... orage-kits
but it seems to be fully overpriced - and not ISO compatible either.
06 Aug 2014, 14:12
I just keep them in bags, most of them are from Signature Plastics.
Want some?
:evilgeek:
Game Theory
Mr. Despair
06 Aug 2014, 14:53
I keep them in bags from 7bit :) on a book shelf.
06 Aug 2014, 15:18
CeeSA wrote: http://elitekeyboards.com/products.php? ... us104_case
That looks identical to the packaging that Leopold uses for their keycap sets. The PET plastic buckles easily.
pyrelink
06 Aug 2014, 15:40
I posted this on reddit a few weeks back. I now use some awesome plastic boxes I found at The Container Store. No clue if you have them in the EU or anything similar, but it should give you a rough idea of what to look for:
http://imgur.com/a/WkVZS
the main storage box in that album:
