[GB] Carrara Marble Keyboard - Osidian TKL
Osidian
20 Aug 2024, 04:07
Contents Page [*]Introduction
[*]Specifications
[*]Component Photos
[*]IC Form
[*]Website
[*]Pricing
Introduction Hello Deskthority members! We're pleased and excited to share with you the Osidian TKL, a gasket-mount keyboard crafted of Carrara marble. Each casing is meticulously crafted with a combination of CNC and hand techniques. Our team specializes in crafting mechanical keyboards out of unique materials like marble and quartzite and aim to create a full line of stone crafted keyboards. Specifications Included In Kit:
- Carrara marble casing
- Magnetic white ABS top plate with stainless-steel emblem
- Adhesive white ABS frame
- 1.5mm brushed stainless-steel switch plate (silicone gasket mount)
- 3.5mm Poron plate foam
- Molex Pico-EZmate cable
- Additional rubber feet (8 degrees)
Colour option/finish:
- Carrara white (more colourways being tested)
PCB & Daughterboard:
- Compatible with Cannonkeys Bastion TKL F12 Hotswap/Solder (F13 not included), and F12/F13 Hotswap combo PCB's.
- Unified S1 daughterboard required
- Please note: The PCB & Daughterboard are currently not included in the kit
- Assembled with our Pico-EZmate cable provided in the kit
Weight:
- Fully assembled approx. 7 LBS / 3.17 KGS
Dimensions:
- Typing angle: 4 degrees
- Front length & width: 375mm x 149mm
- Case thickness: 20mm
Component Photos
Interest Check Form https://docs.google.com/forms/d/e/1FAIpQLScLcdSqNJjpWIcgdDp-C479PPProVzQyKVy2dL8XZEcl_T95w/viewform?usp=sf_link Social Media Discord https://discord.gg/hHAuPaRT3a Instagram https://www.instagram.com/osidiantech?igsh=enp5Nmk3bXo2cGpx Website osidian.ca Pricing Kit Price: 389 USD Group Buy Date: September 15 Group Buy Duration: October 15 Available Units: 100 Units Additional Photos
CAN008 (1).jpg (950.81 KiB) Viewed 11329 times
Thank you so much for your continued interest & support! Best Regards,
DMA
08 Oct 2024, 05:39
Just remember that marble is fragile AF. You drop it on the floor - you'll shatter the case _and_ damage the floor.
It never occured to me before I recently installed a quartz countertop with a marble backsplash.
Heavy AF though. Heavy is good.
