[FMF] Free Model F - Key inserts
idollar
i$
01 Jan 2025, 04:05
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The inserts are considered priority 2, being 0 the highest priority.
As such, at this stage it is important to record constraints that would affect specifications of other components.
Constraints
  • Interface to the barrel and the keycap
Alternatives to be considered
  • Easy to design, 3D print and test in any IBM like keyboard - tolerance shall be respected
  • Mass production
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
