Pulled out the Omnikey to use but I prefer using a buckling spring variant. Probably just needs a good cleaning
and lubrication. Sounds great. Some of the key are scratchy and bind a little from time to time. Hadn't pulled out an old
computer for sometime and felt like it this morning.
Retro Setup
- Falkenroth
- Main keyboard: 1987 IBM Model M 1390131
- Main mouse: Standard Issue Lenovo
- Favorite switch: Catastrophic Buckling Spring
- IMG_9446.jpg (383.32 KiB) Viewed 16517 times
- IMG_9450.jpg (1.76 MiB) Viewed 16517 times
- IMG_9461.jpg (414.54 KiB) Viewed 16517 times
- Polecat
Nice, thanks for sharing. The Northgate goes well with the vintage IBM computer and monitor. Before you tear into the keyboard try typing on it a bit. Alps switches like to be exercised. They can become flaky in storage, and often clear up after a day or three of use.
Falkenroth wrote: 02 Feb 2025, 20:22 Pulled out the Omnikey to use but I prefer using a buckling spring variant. Probably just needs a good cleaning
- Falkenroth
Ok, I will have to run that keyboard for a bit. Thanks
- JP!
- DT Pro Member: 0194
Looks like a fun setup. Thanks for sharing.
