Ipad 3 camera connection kit and filco majestouch 2 mx brown
Mrinterface
26 Jun 2012, 20:11
ripster
26 Jun 2012, 20:51
Bummer your backlit keyboard didn't work, shoulda tried a KBTalking Pure.
http://www.reddit.com/r/keyboards/comme ... kbtalking/
Good luck on the Novel!
captain
27 Jun 2012, 06:21
Truth!
Although, in your video you say that you can connect ANY USB keyboard, which is technically true, but they won't all WORK. HHKB requires too much power and the iPad shuts it down (unless you stick a power insert--a hub-- inline with it)
ImageUploadedByTapatalk HD1340770905.177388.jpg (83.98 KiB) Viewed 2460 times
Mrinterface
27 Jun 2012, 11:11
I just tried it with a HHKB pro 2 and it did NOT work. Probably because of the built in USB hub. I'll update the video with this knowledge. Thanx for pointing this out to me.
Peter
27 Jun 2012, 13:13
Maybe a bluecube would fix the problem ?
ripster
27 Jun 2012, 15:09
Captain tried that despite 0% chance of working.
HHKB doesn't work with purple dongles.
Made for a funny pic though.
One of the PRACTICAL issues is the iPad connector is looser than the morals of a politician with a teenage aide. A Apple Aluminum bluetooth connection is MUCH more reliable.
I'll try pairing my Logitech DiNovo Mini sometime, IIRC the K400 USB dongle did NOT work.
http://geekhack.org/showthread.php?2887 ... put-Tricks
And Reddit tells me that you CAN blow an iPad fuse.
Fuck Reddit.
THIS IS KEYBOARD SCIENCE!
mr_frag
03 Jul 2012, 16:21
kbc poker would work without a powered usb hub?
