Springs!
graboy
02 Jul 2012, 03:29
Hi guys, have a question for everyone. How much force/weight/grams does it take to compress a red/blue/brown spring to 7.5mm (half its height)? This is different from the norm, since I am asking this question about the spring alone, and not while inside of the switch. By the way, you might be curious on why I'm asking this, and if things work out right you'll probably figure it out later, but for now I'll let you speculate. Anyways, can someone help?
Soarer
02 Jul 2012, 03:51
I measured some springs, but not reds. Blues are just under 50g, browns may be slightly less...
From this thread about combos. But beware :lol:
graboy
02 Jul 2012, 05:00
Thanks, that's exactly what I needed.
