An interesting Alps Keyboard I found
daedalus
Buckler Of Springs
02 Jul 2012, 14:53
This was being thrown out by my old college. I will need to dig out a proper camera, and my keycap puller, but here's the obligatory crap cameraphone shot -
Relevant points -
  • Clicky Alps switches. They appear to be some sort of clone (the switches had cream/white sliders, and no Alps logo on the housing) I was thinking XMs, but they are pretty pleasant to type on (smooth, relatively light, noisy as hell). Maybe some sort of Fuhua switch?
  • The lock keys (Caps/Num/Scroll) have an LED on the lower part of the switch, and are linear. I haven't popped one of the caps to see what colour the slider is.
  • Glidepoint touchpad, pretty decent tracking on a high resolution monitor.
  • Short PS/2 Y-cable
  • Pad printed, Dolch-esque keycaps. The F9 key does not appear to be original.
  • Probably from some sort of rack-mounted terminal. the part at the top with the cable holder slides out, and can rotate. There are buttons at the side for some sort of latch mechanism.
  • It has a US ISO layout. Nope, I didn't make a mistake there... go look at the picture.
There's no indication of who made it. I may dismantle it at some point to find some hints.
02 Jul 2012, 14:55
That's great! Just get yourself a better camera ...
rodtang
02 Jul 2012, 16:18
It is from a luggageable PC running NT or something, there was a complete one on ebay for a long time, I look at it for a long time and ended up thinking it was a RD, turns out I was wrong.
daedalus
Buckler Of Springs
02 Jul 2012, 16:21
I wasn't sure if it was luggable, or from a rackmount system. The thing at the back seemed like one of those fold up screens that you see in some server rooms.
Do you remember the manufacturer in question?
02 Jul 2012, 16:49
I've got a rackmount keybaord with a similar layout, but conventional key cap colors and without sleep, wake and power buttons.
rodtang
02 Jul 2012, 17:17
I don't think I was able to find out who manufactured it, opening it up should give you more info than what I have.
Ascaii
The Beard
02 Jul 2012, 19:47
I have a keyboard like this...white alps and green alps on the led keys.
DaXxJaPxX
03 Jul 2012, 15:26
Ascaii wrote:I have a keyboard like this...white alps and green alps on the led keys.
prolly not the same as OP said the LED keys were linear. you should post a pic anyway though
Ascaii
The Beard
03 Jul 2012, 21:00
green ALPS are linear switches.
My unit has a slightly different layout, but the same trackpad...I will bet the switches are identical to mine as well.
My unit is complete...including the 8 port KVM switch, monitor, and 19" rackmount.
