Green fluid on the connector (Model F)
Andre.S
05 May 2025, 15:11
Can I continue using the keyboard as is?
The fluid is odorless. It is detected after the Soarer converter has been connected for a while. I wiped it off, but it's still unclear if there's any residue. Otherwise, the keyboard works perfectly.
model
model
color
color
Falkenroth
05 May 2025, 18:17
Looks like some kind of dielectric grease to me. Somebody probably just trying to protect it from corrosion.
modelf
05 May 2025, 19:43
I acquired, later sold, a 1981 model F (XT) keyboard with green greasy stuff on the DIN5 connector. I just assumed it was put there by IBM.
AndyJ
08 May 2025, 03:12
A normal PC-XT Model F has 1u striking surfaces on all keys, even when they're 1.75 or 3u.
Only the keypad '+' key is like that on this board. The rest of the keys have tops the same as their bottoms. And I've never seen a beveled Enter key like that.
Is this an example of one of those "stick on cover" kits, or custom keycaps, or some kind of terminal keys on a "Personal Computer" badged board?
Polecat
08 May 2025, 03:43
My F-XT has the black version of those. Stick on covers, with the original caps underneath. Mine has a plain IBM badge, no "Personal Computer". No model number unfortunately, but it speaks normal PC/XT. .
viewtopic.php?p=485652#p485652
A couple replies down I posted links to a few more examples and some history and details.
JacobMurphy
16 May 2025, 14:02
Thank you so much for sharing the link.
