Hi all,
I recently got my hands on the YKASEK DK6 Ergo, and I figured this community might be the right place to dive into a deeper conversation about it — especially for anyone into split layouts, custom builds, or unusual configurations.
TL;DR:
88-key fully modular & magnetic split keyboard
Hot-swappable switches
Multi-layer key mapping
True customization with macro support
Ergonomic split layout with low-profile aluminum base
USB-C wired only (currently)
First Impressions
Let’s start with what makes this keyboard stand out — it’s not just “modular” in the marketing sense. The entire keyboard is composed of magnetic modules, allowing you to reposition each key (yes, individually!) to match your exact hand positioning, shoulder width, or even ortholinear preferences.
Think Glove80 meets hot-swap LEGO.
Each half sits on a thin aluminum base, only 5.6mm thick, making it stable but low enough to rest your wrists comfortably without a wrist rest. The keyboard includes RGB backlighting, which can be configured per layer, per key, or turned off if you’re more of a minimalist.
Customization & Ergonomics
One of the strongest points is its fully customizable key mapping — 4 programmable layers with macro capability. Whether you want a gaming layer, a Vim layer, or a full numpad setup, it can be done. Everything is handled via their configuration tool (currently desktop-based, web version is rumored to come).
What’s also neat is that it supports standard keycaps. I'm using a set of PBT double-shot pudding caps right now, and they look fantastic under the backlight. They also provide two sets of keycaps by default (for ANSI and ISO, or color swap — depending on the batch).
Concerns/Things to Note
The base is wired-only (USB-C), which ensures low latency but might not be for everyone.
Software is not open source yet, which I know is a common preference here.
Key modules are magnetic but still fairly secure. Not for violent typists, but solid enough for daily work/gaming.
Currently ships with linear switches by default, but you can hot-swap to anything MX-compatible.
Ideal Use Case
This board is ideal for:
Developers or writers who type for long periods and need ergonomic positioning
Custom layout fans (Dvorak, Colemak, or your own creation)
Tinkerers who like building their own layout
People who want a clean setup with aesthetics + function
Final Thoughts
This isn’t a board for everyone — if you want plug-and-play and are overwhelmed by options, this might be too much. But if you love diving into layouts, ergonomics, and modularity, it’s a refreshing take on mechanical keyboards. I’d love to hear if anyone else has tested it or has similar preferences!
Let me know if you have any questions or want pics of the internal structure/mounting system. Happy to share!
Cheers,
— YK Enthusiast (no affiliation, just nerding out)
YKASEK DK6 Ergo – A Truly Modular Split Keyboard for the Tinkerers and Typing Nerds
ykasek
- Main keyboard: YKASEK DK6 Ergo
- Favorite switch: Kailh Box White / Gateron Brown
- 448919977_786696563580538_1599746068140988733_n.jpg (162.87 KiB) Viewed 1440 times
- 448911862_823208439396132_6429800108370824490_n.jpg (119.46 KiB) Viewed 1440 times
