Vintage Keyboard Identification
jws
11 Mar 2026, 15:20
Hi community,
I just rescued an old keyboard from a dumpster and am trying to find out which model it is.
No outside markings except a faded inventory number and a sticker from a company selling electronics for the disabled. The keyboard was fitted with an acrylic pane with holes to aid people with motor impairments, so this makes sense. German ISO-DE layout. Clicky Cherry MX blue switches. 5-pin DIN type connector with an AT/XT dip switch on the back. Two PCBs inside connected by wires, the larger etched with "T145" and a sticker "144 T175", the smaller with a sticker "Pro1 1530". Googling neither of those terms returned any useful results.
Maybe the case is custom or customised to fit the threaded inserts for the standoffs of the acrylic cover? But then again the PCBs most likely is stock and I could find no keyboard with that layout either.
One last thing: the company sticker on the back already has a new 5-digit zip code. Zip codes were reformed in Germany in 1993, so the keyboard was sold after that point although the model itself could be older.
I could not test whether the keyboard works, but as a far as I understand I would need an 5-pin to PS/2 adapter and then another active PS/2 to USB adapter to make it work, right?
Thank you for any help and pointers.
11 Mar 2026, 17:58
Did you try to simply call the phone number on the sticker?
And a search for "Färber + Reteaca" retrieves a "Rehakomm (instead of Rehacom) Peter Jacobi" with different addresses and phone numbers over time.
Green Maned Lion
11 Mar 2026, 21:40
You could just get a DIN180 to USB active converter...
jws
12 Mar 2026, 10:40
kbdfr wrote: 11 Mar 2026, 17:58 Did you try to simply call the phone number on the sticker?
Thank you for the tip. I also found the website of Rehakomm and Reteaca, they are still in business but obviously do not sell that model anymore. I thought identifying the model through its unusual layout would be easier than calling someone about a keyboard his company sold 30 years ago.
Green Maned Lion wrote: 11 Mar 2026, 21:40 You could just get a DIN180 to USB active converter...
Thank you as well. I did not find such an adapter on aliexpress, so I just ordered the two others. Can you recommend a cheap one? I only found one on etsy for $40+.
Green Maned Lion
12 Mar 2026, 19:42
The one on ebay from Tinkerboy is a good quality converter.
