Lexmark M5-2 Buying
486
10 Jul 2012, 09:46
I saw a Lexmark branded (not IBM) M5-2 on ebay for $60 total. Should I get it?
Also it has the AT/serial instead of the two ps/2 connectors.
I don't know how much these are worth.
Also is the M5-1 better than the M5-2 or vice versa in your opinion?
maxrunner
10 Jul 2012, 17:20
I have the M5-2 from IBM if you want. I want to sell that and a M5-1. Both were bought from Clicky Keyboards.
486
10 Jul 2012, 22:20
How much do you want for them?
Also where are you located so I can calculate postage.
maxrunner
11 Jul 2012, 09:53
Hi! I need to check how much i bought them for.
Edit: i'm from Portugal.
