DAS Keyboard Lovin
jcrouse
- Main keyboard: KMAC
- Main mouse: Razer Deathadder 3500 Black Edition
In the past fe days I have seen a few post regarding DAS keyboards. Ya don't see many here. Why is that? Are they not plate mounted and very sturdy? Is the quality poor or is it just the goofy case?
Thanks,
John
Thanks,
John
- dorkvader
- Main keyboard: Unicomp
- Main mouse: CST 1550
Well it depends on the DAS. I don't have one, but I believe the first was RD, the second Gen ones was a rebadged cherry (Which everyone here has, it almost seems a requirement of joining) and the third-gen ones are expensive.
I mean, People here clearly own DAS. There was just a post recently about them. In my opinion, there are better options, though. When I first became interested in this subject (and was too poor to get a mech keyboard) I considered DAS, but decided to keep my Model M. I still don't like that glossy case. Even with the branding I prefer my matte/rubberized CMstorm.
Perhaps some DAS users here will chime in.
Link to topic:
http://deskthority.net/keyboards-f2/whi ... t3292.html
Link to topic:
hoggy
- Main keyboard: Kinesis Advantage
- Main mouse: 3M Vertical
- Favorite switch: MX Brown
- DT Pro Member: 0009
The marketing puts me off Das as a company. The boards are nothing like a model m - I wish they'd stop saying it, and especially stop saying it to journalists. Nothing against some of their keyboards.
ajdane
- Main keyboard: Das Keyboard
- Main mouse: G500
- Favorite switch: MX Blue
I have a DAS Ultimate. I quite like it. Though after bouncing around this forum for a week or so and being bitten by the keyboard bug. Im definitely branching out more. (HHKB and Model M on the way).
I will say that its not a bad Keyboard at all. The only minus is the glossy black surface. It does attract fingerprints and smudges. Though just after cleaning it really looks awesome. Typing wise its great (though i have limited comparisons still) the blues feel crisp and give good feedback but they can get a bit noisy if you are typing furiously.
I have the blank keycaps, I really like the all black look, and after reading about the fading / yellowing of the text on the professional i must admit im happy with my choice.
Its also fun having a colleague or a consultant come over (I use the DAS at work) and do a double take over your keyboard.
gbohn
- Main keyboard: daskeyboard Professional S w/Cherry DS
- Main mouse: Kensington Orbit Trackball w/scroll ring
I was wondering how hard you found it to remove and replace the key caps with sabilizer bars underneath. Were you able to slide they key cap toward one side to release the cap from the bar, or did you need tools to pry one end of the bar out of the white holder?
Thanks;
gbohn
Thanks.jcrouse wrote:I actually use a paper clip, bent with a small hook on the end, to reach in, hook the wire, gently pull it to the side and lift the cap up.
To replace the key, do you just do the reverse? (With the white holders in the new keycap, slide the one side on the bar and then use the tool to pry the other side of the bar enough to make the final connection to the other white holder?)
maxrunner
- Main keyboard: custom 60% holypanda
- Main mouse: ergo m570/m575
- Favorite switch: current holy pandas
jcrouse wrote:In the past fe days I have seen a few post regarding DAS keyboards. Ya don't see many here. Why is that? Are they not plate mounted and very sturdy? Is the quality poor or is it just the goofy case?
Thanks,
John
What does it mean plated mounted compared to the other methods?
Paulie
- Main keyboard: IBM Model M
- Main mouse: Logitech M570
- Favorite switch: BS/Cherry MX Brown
I found it pretty straightforward. Firstly I removed all the keys around the stabilised ones, then I could slide the stabilisers sideways to unhook them. After that I swapped the little white holders to the new keycaps, slid them back in, then replaced the surrounding keys. Hope that helps!gbohn wrote:
Thanks;
- Daniel
- Main keyboard: Various
- DT Pro Member: 0028
Full acknowledge for that.ajdane wrote:I have a DAS Ultimate. I quite like it. [...] the blues feel crisp and give good feedback but they can get a bit noisy if you are typing furiously.
I like the build in usb-hub (the das has actually two usb-connectors, one for the keyboard itself and one for the hub). I use the hub to plugin a mouse from time to time if feel the need to play a first person shooter.
The blank keycaps started to get shiny within 5 months of normal use (you should be able to spot it on the f and j-keys in the picture). But this was the case as well on my old Logitech keyboard which also had black keycaps. Therefore this is no DAS specific problem.
- Das Keyboard Ultimate
- DSCF9551-entzerrt.JPG (62.63 KiB) Viewed 4511 times
