Do blank, white, pbt keycaps get dirty quickly?
rhizo
15 Jul 2012, 18:49
That is the question. Do blank, white, pbt keycaps get dirty quickly?
MagicMeatball
15 Jul 2012, 19:00
That depends on how dirty your hands are when you type :P
15 Jul 2012, 19:01
That depends on how much booze you give them.
rhizo
15 Jul 2012, 19:56
Keep up the informative responses guys!
Peter
15 Jul 2012, 20:15
rhizo wrote:Keep up the informative responses guys!
You are asking if WHITE keycaps get dirty !
rhizo
15 Jul 2012, 20:31
I think you will find there is a little piece of text that is present after the word dirty in my title. I am merely asking indirectly if they are easy to clean and if they get dirty fast enough to be more than a minor annoyance.
Thanks,
thegunner100
15 Jul 2012, 20:36
Depends on how dirty your hands are, and how often you use the keyboard. Blank/engraved white keycaps are very easy to clean though, just soak them in bleach and they'll come out white again.
MagicMeatball
15 Jul 2012, 20:54
thegunner100 wrote:Depends on how dirty your hands are, and how often you use the keyboard. Blank/engraved white keycaps are very easy to clean though, just soak them in bleach and they'll come out white again.
That's pretty much what I said. lol.....
If you keep your hands dirty while typing, then you can expect the keycaps to get dirty. If you wash your hands before typing, then I guess you won't have that issue....
rhizo
15 Jul 2012, 21:00
Anyways, thanks guys, gonna just get them and see what happens... I don't generally like to do obstacle courses before using my keyboard so I will assume that they should stay white for long enough.
dorkvader
15 Jul 2012, 23:36
All my PBT keycaps get dandruff on them faster than they get actually dirty. My unicomp ones haven't been cleaned ever (since December 2010), and they still look clean. Now they're light grey instead of white, but I imagine the principle holds.
Limmy
16 Jul 2012, 01:29
I saw ripster's post at GH while ago on how white engraved PBT caps attract grime over time. It was not pretty.
EDIT: found ripster's photo with stained white PBT on OCN
Also it seems to me that some of the keys have yellowed a bit.(not talking about Japanese flag keys; alpha keys are slightly yellow compared to modifier keys.) See here
kaiserreich
16 Jul 2012, 07:25
That's from the grime. Once you clean them up with soap or denture tabs, they are as good as new.
rhizo
16 Jul 2012, 13:07
kaiserreich wrote:That's from the grime. Once you clean them up with soap or denture tabs, they are as good as new.
Thanks, this is the golden comment I have been looking for. Congratulations on your award!
