Sun type 5c
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
Someone wanted some photos.
- Sun5c_001.jpg (197.4 KiB) Viewed 7103 times
- Sun5c_005.jpg (447.53 KiB) Viewed 7103 times
- Sun5c_004.jpg (235.84 KiB) Viewed 7103 times
- Sun5c_003.jpg (241.13 KiB) Viewed 7103 times
- Sun5c_002.jpg (555.74 KiB) Viewed 7103 times
- 7bit
I recommend to make WYSE clones instead. The colors are similar and SP did the originals, so no problem for them to do 'em again.
WYSE colors are a bit nicer. The light grey and grey are too similar on the type 5c.
- kint
- Main keyboard: g80-8200/ FK-2002
- Main mouse: genius netscroll optical gen1
- Favorite switch: MX clear/ Alps white comp
I agree with that, although I like that.7bit wrote:... The light grey and grey are too similar on the type 5c.
Mine with the DE layout however features the Control in its regular IBM position. Is you caps lock illuminated down there 7bit? Too bad these don't have nice switches...
- DT Pro Member: 0011
Rubber domes by Fujitsu. The key caps are somewhat compatible with other Fujitsu-made keyboards.
I like that the key caps are sharp. This is one of the most beautiful keyboards ever made, in my opinion.
- Elrick
- Main mouse: MX518
I'm also interested in these. Can a Type 6 keyboard be used in Windows as well?kint wrote:So they definitely exist in two versions, Linux/Unixlike and IBM/PC/Windows.
Completely ignorant when it comes to Sun Keyboards in general. Please excuse my utter newbness here.
Can anyone direct me to a site that explains in detail what version(s) of Sun keyboards that can be easily used in Windows?
The Sun Type 6 has USB, so it can be used with a Windows PC. It is built different and is not good-looking at all, but it has mostly the same layout.
The Sun Type 5 seen here runs an old Sun protocol. I have seen on the web schematics and open source firmware for a PC-compatible controller as well as a protocol converter for sale in a Japanese online store, but sadly, I did not bookmark these links, sorry.
- kint
true. I remember when I first had to work with what probably was a late SPARC or an early ULTRA station with ~Solaris 7 and CDE back in the days...felt so lost coming from WIN95 then.
Probably typed on a 5c then, can't remember.
For those interested, here's how they look like inside:
http://www.velocityreviews.com/forums/t ... d-mod.html
converter for PC use projects I dug up when I thought about my unit, some abandoned, some with obsolete Hardware though:
http://www.snafu.priv.at/mystuff/sunkbd.html
http://www.buzzard.me.uk/jonathan/sunkbd.html
http://www.bedroomlan.org/hardware/sun-keyboards-usb
- Charlie_Brown_MX
- Main keyboard: Apple Extended Keyboard
- Favorite switch: ALPS: cream or salmon
I’m surprised to see that it has a seperate dome for each key, though I suppose that would explain why it doesn’t feel crappy.kint wrote:For those interested, here's how they look like inside:
I’m trying to resist hunting down one of the *nix layout ones. I need to have a clear-out and get used to ANSI before I buy anything else.
- Vax
- Main keyboard: Filco & Browns, Vintage Cherry Doubleshots
- Main mouse: Zowie FK, QCK+
- Favorite switch: Browns
Thanks for the photos 7bit!
Still thinking about making a GB for these. Not sure if I want to use SP for it since I don't like the recent quality of their caps at all. But if you say they did the originals (which I can hardly believe) I guess SP would be the better option instead of QWERKeys for those. Also not sure how accurate QWERKeys could copy the set with their engrave/enfill method.
What do you guys think?
ChoiYoungGyoo
- Main keyboard: KMAC Titan Winkey
- Main mouse: Razer Mamba 4G
- Favorite switch: variable black cherry mx
This keyboard is very attractive...
I hope to get this one..
nice pics..
nice pics..
- kint
I do think 7bit meant that SP did the WYSE caps OEM, not the Sun ones.Vax wrote:Thanks for the photos 7bit!... ...What do you guys think?
Apart from that: Do you plan to answer my pm which was a reply to your sparse inquiry about my 5c?
edit: ftr: type 5c boards come with some sort of proprietary connector, size of PS2 but without centering stem inside and 8pin connector instead.
- dirge
Was it a 5c? was it custom converted? The sun sparc 5 had the din plug but I didn't know of one with usb. The sun 6 I think had one.fossala wrote:I bought my usb one to see if I liked the HHKB/Sun type/UNIX layout. It's now just in a closet. The thing is horrible.
- 7bit
They did the original WYSE key caps, which are similar to the Sun keyboard style (I don't wonder much about that, BTW).Vax wrote:Thanks for the photos 7bit!
- 7bit
They are not special (rubberdomes). Just the Sun logo on them makes them special.Zehkul wrote:Wait, those sun boards actually are something special? I’ve seen so many of those
