Transparent J series
Sleabo
25 Jul 2012, 12:25
Available soon! 8-)
damorgue
25 Jul 2012, 12:36
Transparent or opaque?
Legends?
cactux
25 Jul 2012, 12:40
Sleabo
25 Jul 2012, 12:57
Both transparent and translucent(just checking this will have an answer this afternoon)
Legends can be engraved and infilled on either top face or front face as normal
cactux
25 Jul 2012, 13:15
Sleabo
25 Jul 2012, 14:54
Yes ABS
Icarium
28 Jul 2012, 00:22
Ooh, sounds awesome. :)
Limmy
28 Jul 2012, 14:32
Want to see pics, decent pics not pics taken with a phone like last time!!
Opaque letters on translucent would look awesome. I hope the caps with translucent material are thick as possible.
Acanthophis
28 Jul 2012, 14:36
This also applies to the B series?
Transparent base with red top seems nice in my imagination.
Sleabo
28 Jul 2012, 17:40
Hi guys, so we can do this transparent material in B, J and K series. With the B series you could have a transparent side and an opaque centre.Check sample pics:
IMG_4069 (Large).JPG (38.94 KiB) Viewed 3702 times
IMG_4073 (Large).JPG (34.12 KiB) Viewed 3702 times
Thanks
Acanthophis
28 Jul 2012, 17:55
Looks nice!
Limmy
29 Jul 2012, 02:26
Is there anything that can be done to get rid of the cross mark? I didn't imagine to see those marks. Can't Same material be filled in so that there is one solid chunk of the translucent material? The current model seems to be that the stem is different material and it kind of gets in the way.
quake4mhger
29 Jul 2012, 02:49
Omg! looks awesome!!! Let's do groupbuy :lol:
GMC
29 Jul 2012, 10:51
Intriguing.. you can label the front face I presume? What colour options have you got for the body? If you have anything like a burnt copper or burnished metallic effect then I definitely want some!
Sleabo
29 Jul 2012, 11:29
Yes we can label the front face. The sides or centers only come in our standard colours so far which are on the website in keycaps info.
Thanks
