Zoom causes problems
Icarium
25 Jul 2012, 21:57
I think this is new but anyway: If you just zoom in with Firefox in some board then at some point the topic list jumps to the right. Looks weird.
trax
03 Sep 2012, 21:59
You mean zoom in with the FireFox plugin?
If so. DONT USE IT. I get so many complaints from customers that my designs aren't lignin out nicely. I honestly don't get why they even implemented that feature.
Icarium
03 Sep 2012, 22:52
Because it's great? Zooming is just plain useful.
trax
03 Sep 2012, 23:41
For what?
04 Sep 2012, 01:36
Use Ctrl + instead of buggy software ... :roll:
Icarium
04 Sep 2012, 09:47
I use ctrl + mousewheel but it's the same thing.
Icarium
04 Sep 2012, 09:54
Here are two pictures illustrating the problem:
Want.
Want.
Do not Want.
Do not Want.
There is exactly one step of Firefox zoom between those two.
mintberryminuscrunch
04 Sep 2012, 10:24
strange, mine works just fine
Icarium
04 Sep 2012, 10:41
You have to be on a site that has a searchbox, like marketplace and zoom about 4 times from the default. At least that's what seems to screw it up for me. :)
04 Sep 2012, 11:07
Icarium wrote:You have to be on a site that has a searchbox, like marketplace and zoom about 4 times from the default. At least that's what seems to screw it up for me. :)
works fine on my end,too.
JBert
04 Sep 2012, 11:23
Also looks like a Firefox bug to me...
Icarium
04 Sep 2012, 11:30
I haven't looked at the source of the page so I have no idea.
29 Sep 2012, 02:10
This should fix it:
.forums-wrapper {
	clear: both;
It's a bad interaction with floats, which causes the topic list to left align relative to a float once the height of the float increases too much.
Return to “Deskthority talk”
