Keycool 84
bebuxe
27 Jul 2012, 12:16
Yeih! It works just like advertised!
Getting used to reds MX.
h;urei
^proof it is 6KRO on USB
them pics (excuse the quality, only have a cell phone atm):
Nice Package
Nice Package
The case:
The case
The case
Inside the Case:
Inside case
Inside case
Le Contents:
The contents, with the added stuff.
The bags:
The bags
The bags
That keyboard:
tan tan TAN TAAAN
tan tan TAN TAAAN
Yes they are cherry red:
Yes, I got the reads because I am still a teenager inside.
The back:
The back
The back
The legs:
The legs
The legs
The port:
The port
The port
Pros:
1)cheap MX USB de-attachable keyboard, with all the actual necessary ISO/IEC 9995-2 inputs, and more.
Bloopers:
Print_screen Scroll_lock and Delete are First
With FN: Num_lock Pause and Insert
[who gets that?]
Adding a part 2
fossala
Elite +1
27 Jul 2012, 12:22
How cheap does it feel, what can you compare it too? Have you tried a Choc mini?
bebuxe
27 Jul 2012, 12:28
Part 2:
More on the USB port:
Plugged in and everything.
For the LED maniacs:
damn LEDs
damn LEDs
Those LEDS!
Those LEDS!
Those weird FN inputs:
fn 1
fn 1
fn2
fn2
fn3
fn3
The sidebar
The sidebar
That  Shift key.
That Shift key.
them numbers
them numbers
Adding part 3
>fossala
Do not know how to answer that. Plastic cheap? But Red MX feels awesome, like I am pressing on butter pellets. But let me finish lol. Please read my profile too.
bebuxe
27 Jul 2012, 12:49
Le manual:
It's all Mandarin to me.
Come again?
Come again?
what?
what?
Ok, clearly I am not getting it.
ok...
ok...
and how does turn ON the Flux Capacitor
And they lived happily ever after. The end!
If you can read:
The back label
The back label
Height:
sit
sit
rise
rise
part 4 coming up, after "My Life as a Teenage LoveBot"
fossala
Elite +1
27 Jul 2012, 13:17
How does it compare to the Choc Mini then?
bebuxe
27 Jul 2012, 13:34
Part 4, the dawn of doom
The keycap size:
Base: 1.8cmx1.8cm
Top: 1.25cmx1.4cm
Height: max 1.2cm, dip 1.1cm
Images for fun:
length
length
width
width
height
height
some of the extras
some of the extras
nasty
nasty
And yes it works. I typed some of it on it:
see
see
i told you.
i told you.
Song playing in my head while doing this:
http://www.youtube.com/watch?v=9lNZ_Rnr7Jc
I need to do usb-devices and the other commands later on fedora.
Tell me what others to try. I feel like a fledgling anyways.
Any questions?
bebuxe
27 Jul 2012, 13:42
>fossala
Dubs, check 'em:
The are like twins. 'cept one dumber, and the another dirty.
bebuxe
28 Jul 2012, 01:13
Deetz from fedora:
usb-devices:
T:  Bus=05 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0001 Rev=03.04
S:  Manufacturer=Linux 3.4.4-4.fc16.x86_64 uhci_hcd
S:  Product=UHCI Host Controller
S:  SerialNumber=0000:00:1d.3
C:  #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
T:  Bus=05 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  3 Spd=1.5 MxCh= 0
D:  Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=04b4 ProdID=0101 Rev=00.01
S:  Manufacturer=Cypress
S:  Product=Cypress USB Keyboard / PS2 Mouse
C:  #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=100mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=03(HID  ) Sub=01 Prot=01 Driver=usbhid
I:  If#= 1 Alt= 0 #EPs= 1 Cls=03(HID  ) Sub=01 Prot=02 Driver=usbhid
lsusb -v
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0001 1.1 root hub
  bcdDevice            3.04
  iManufacturer           3
  iProduct                2
  iSerial                 1
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval             255
woody
Count Troller
28 Jul 2012, 11:28
bebuxe wrote:Any questions?
What key combos are hardwired via the Fn key? Scan codes would be cool, too.
bebuxe
28 Jul 2012, 14:20
nice idea....
running xev would a pain though.
Also I forgot to say some Cons:
USB hole for the cable is improperly designed, and it causes the wire to compress. I even made a dent on the insulation. But nothing a knife a can fix.
From the build, there are no screws. And looks to be glued shut. So no hacking, unless you got glue, and a knife.
That Delete key up on the top confuses me, esp. when doing Shift + Fn + Insert. But there is always setxkbmap.
Caps do not feel like ABS from Noppoo, but the letter are sticker, or what ever it is called.
I guess winkey is non standard size.
Hopefully I will some free time tomorrow to test them all.
blighty
29 Jul 2012, 16:29
Nice review. I ordered a black one with black switches last week, mainly to use as a backpackable gaming keyboard (hopefully is shows up in the next week or so). The main attraction I had to this board over the Noppoo was the detachable cable. The Race has a removable cable as well I realize, but I like the fact the the Keycool mini has the connection underneath with the cable crimped, to prevent accidental unplugging. By your comments about the USB channel compressing the cable, it sounds like it will meet my needs nicely.
fossala was asking about "cheap" feeling of the board. I'm not expecting too much for the price, so I figure plactikoting the case may add a bit of ruggedness to it.
Have you taken off the spacebar to see what it's compatible with? It looks like it's Filco length, just curious if the mount points line up.
bebuxe
29 Jul 2012, 22:44
>blighty
Well, for the cable being compressed worries me about cable's durability. But that is why you have a knife with you always.
And I can't still answer a question like that. It's like saying, "How red does it feel?" And I would have to answer the same, "Red feely?". If he means something like, "What type of materials is it composed of, esp. the Keycap and base exterior plastic?" I would have a more definite answer: "I apologize, but I do not have testing materials or the resources to test the Plastic, or the motherboard."
I will check the space bar later. Tried fidgeting with it, but I got to run to work. The life of a full time worker is not easy. Tell me the dimensions of a filco kb's space bar.
blighty
30 Jul 2012, 03:44
The DT wiki http://deskthority.net/wiki/Space_bar puts the Filco's space bar at 6.25 units (118mm (just over 4 3/8 inches) wide, 3 mounts, 50mm apart). From eyeballing the pic it looks the same, but no way to tell about the mount points without looking underneath.
As for build quality, do you think the case would break/crack if you had to hit someone over the head with it a few times :D (or at least survive a 2 or 3 foot fall) ? Plastic bat vs wooden vs aluminum I guess. I suppose I can decide for myself when it arrives.
bebuxe
30 Jul 2012, 23:57
>blighty
I'll check tomorrow.
Build.: You can mash someone head 3 times and it will break. A 10 feet fall would make break. Between Plastic - wooden.
>woody
Kinda busy for xev map. Need to orchestrate it. Scripts are welcome.
woody
Count Troller
31 Jul 2012, 00:11
bebuxe wrote:Kinda busy for xev map. Need to orchestrate it. Scripts are welcome.
A short compiled combo list like for example "Fn+A gives ...." is still a good start.
"xev | grep keysym" is a quick way to filter the output, but you'll still get on/off/repetition events. Of course you don't need to check the codes for the regular keys.
raptorized
31 Jul 2012, 01:15
i just got my white keycool 84 with red switches
bebuxe
31 Jul 2012, 09:47
>raptorized
nice.
>woody
I did it the simple way:
Esc      F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12  Print Pause Delete
`        1  2  3  4  5  6  7  8  9  0   -   =    BackSpace   Home
Tab        q  w  e  r  t  y  u  i  o  p  [  ]    \           Prior
Caps_Lock   a  s  d  f  g  h  j  k  l  ;  '   Return         Next
Shift_L      z  x  c  v  b  n  m  ,  .  /  Shift_R     Up    End
Control_L Super_L Alt_L space Alt_R Fn Control_R Left Down Right
With FN the only diff. are the Fn keys and Fn12 which does something to
light up the LED and it looks like a Lock. But it does not do anything.
Esc XF86Explorer XF86HomePage XF86Calculator XF86Tools XF86AudioPrev XF86AudioNext XF86AudioPlay XF86AudioStop XF86AudioMute XF86AudioLowerVolume XF86AudioRaiseVolume [Fn lock?] Num_Lock Scroll_Lock Insert
Nothing else for FN that I could find.
Numlock is visable in the image I made earlier. But I shall pasta the map.
7 8 9 0
 u i o p
  j k l ;
   m , . /
With Numlock
7 8 9 /
 4 5 6 *
  1 2 3 -
   0 00 . +
Maybe there are notes from the the manual or the home page ? Any notes
from http://kbtalking.cool3c.com/ ?
raptorized
31 Jul 2012, 10:11
woody
Count Troller
31 Jul 2012, 10:35
@bebuxe: Thanks!
bebuxe
31 Jul 2012, 12:40
>raptorized
NICE. But I am making/buying/getting my own caps later (opinion/taste difference, nothing wrong with that).
>woody
You are welcome. The total will be 22 USD with State Tax. Will it be paypal or check?
>et al.
Anyone got any other Qs? I shall be lazy enough not to document this on the wiki (were most of this should be).
woody
Count Troller
01 Aug 2012, 10:44
bebuxe wrote:>woody
I don't know. :D You have somebody else in mind with respect to the quoted price. Please check again.
blighty
03 Aug 2012, 20:25
Just so everyone knows, a filco spacebar fits the mini84 with a replacement stabilizer (I got one from wasd keyboards) and moving the stabilizer mounts to the outer positions. It's rad that all the keys can be swapped with aftermarket keycaps with a little modding.
raptorized
05 Aug 2012, 07:09
Have you tried to remove the case? I don't know how to do it safely
bebuxe
05 Aug 2012, 10:12
No, I have not. An I do not want to yet. Until I can get better at typing on the typematrix 2020. Plus, I do not got time to get glue and hack my way at the keyboard. Unless I buy another, lol.
Return to “Reviews”
