A handy, pocket-sized, IBM opener
Soarer
17 Aug 2012, 03:32
Made by Melco, 75mm long, from here.
4BA = 0.248 inches
5BA = 5.59mm
Not pretty, and 5BA is a bit sloppy on 5.5mm, but it works OK. Could do with some tidying up of sharp edges.
:D
HaaTa
Master Kiibohd Hunter
17 Aug 2012, 05:15
Neato!
It would fit nicely on my key-ring tool box.
You never know when you need to open up a keyboard in the wild! :mrgreen:
(Currently I have a philips, flat-head, and mini adjustable wrench, which are usually sufficient for most basic situations)
Soarer
17 Aug 2012, 16:43
HaaTa wrote:(Currently I have a philips, flat-head, and mini adjustable wrench, which are usually sufficient for most basic situations)
Just add a hefty mallet, and you're set to completely strip-down and reassemble a Model F... anywhere! :lol:
