Tipro keycap replacements.
fossala
Elite +1
03 Sep 2012, 09:21
Is there anyway to get keycap replacement for qwerty tipro boards, including the space bar?
Djuzuh
03 Sep 2012, 11:08
R4 mwahahahaha ! :evilgeek:
fossala
Elite +1
03 Sep 2012, 11:13
Does R4 actually have them? Including spacebar and all the keycap sizes? (silly shifts)
fossala
Elite +1
03 Sep 2012, 11:46
OK seen round 4 SPH has the spacebar, is this the only set? Also can I get the other correct size keys (shifts ctrl windows alts).
03 Sep 2012, 12:45
Depends where you want to have them, Tipros are fuly programmable after all.
Any MX compatible keycap will do.
But in any case, there is one keycap you will not be able to replace: the "/' (assuming an ANSI keyboard) because it is 1.25 instead of 1.0. Obviously Tipro wanted to have a 2.0 instead of a 2.25 Enter key and made the key immediately left of it wider to compensate for that. Silly idea :cry:
I'm having a Tipro modded to correct that. Hope to get it soon and read a review here ;)
