What switch is this?
11 Sep 2012, 16:25
It came on a "PC Partners by Leading Technology, Inc" that I scrounged off a junk pile yesterday.
I can't find it shown anywhere, it has a nice clicky feel and a few dead switches (~5).
Trying to decide whether to try to fix it, or harvest the keys and toss it. I don't need another project, but this has me interested.
what01 (Large).jpg (533.92 KiB) Viewed 3857 times
IvanIvanovich
11 Sep 2012, 18:17
No markings on the housing at all? It looks familiar but I can't remember the name of it. I want to say MEI but I don't know if thats right.
Icarium
11 Sep 2012, 18:20
As mentioned on GH it looks like Futabas to me. But the case is different.
Daemon Raccoon
11 Sep 2012, 18:40
SMK Whites (non-vintage).
11 Sep 2012, 18:48
Great, thank you.
I like clicky tactile and would need to swap 5 keys around to make it useable.
Are these considered desirable switches, and therefore is it worth the time and effort with the soldering iron?
Daemon Raccoon
11 Sep 2012, 18:50
If you like them, I'd consider it worth it. :)
Icarium
11 Sep 2012, 18:56
I've never ever seen anybody ask for them so I wouldn't say they're desirable in the sense that you could sell them. I doubt that anybody has tried them, though. :)
11 Sep 2012, 19:11
When I got the board it was broken (L was pulled up from the PCB). I clicked it a bit, unplugged, and it seemed OK.
I took it apart and pulled the keys. Miraculously, a one-move re-soldering of the broken contact fixed the L switch.
I clipped on a ground wire and plugged it in naked, with no keycaps, and tested it. I found that there were 5 dead switches.
I, numpad 3, numpad 9, =+, [{, and Print Screen
Some time spent with the soldering iron could move enough switches around to make it useable for me. I just need to decide whether I want to spend the time and energy on it.
These are the type of switches that I normally prefer, and I have never had them before, so I may do it.
Does anybody know whether they will interchange with anything else, and/or does anybody have 5 spares?
thanks, Harry
bhtooefr
11 Sep 2012, 19:26
If you can find a Laser keyboard (usually has an AT plug), it uses the same switches typically.
I've liked them when I used them, although they're way too easy to bottom out.
IvanIvanovich
11 Sep 2012, 19:48
Oh, I knew it was something with three letters name.
11 Sep 2012, 20:22
Yep, the housing looks like SMK. Is there no plate to stabilize the switches?
bhtooefr
12 Sep 2012, 04:14
The Laser keyboards I've had look a lot like that, and, no, it's PCB mount on a really thin and flexy PCB.
Ascaii
The Beard
13 Sep 2012, 22:19
I must admit these are my favorite switch and I much prefer them to Cherry blues. I had a Laser keyboard, which unfortunately was defective so I couldnt use the board, and have been searching since to find a working one. Definitely a fun switch to have and try.
Icarium
13 Sep 2012, 23:32
Do you still have it? :)
Ascaii
The Beard
15 Sep 2012, 15:34
Im sending it to MrInterface for the next iteration switch try bags.
domin8r
17 Sep 2012, 13:27
I have a donor board so I can send you spares if you'd like :)
Switches are compatible with MX keycaps by the way, makes it a bit more interesting IMHO
Ascaii
The Beard
18 Sep 2012, 18:49
Yep, I love the switch, but am not going to attempt to repair my board...MrInterface needed the switch anyways.
One interesting fact about the Laser PCB...it is prepared for an extra 5 switches between arrow keys and the block of keys above it, theoretically allowing a full 3x5 matrix if you modify the case and solder in the switches.
Once I finish my bachelors thesis and find a little time in my life I will try to find myself an SMK board and modify it to my personal preference...mainly removing the big ass enter and replacing it with an iso enter.
